A/C compressor replacement
DQBB2018
  • 2003 HONDA ACCORD
  • 3.0L
  • V6
  • 120,000 MILES
My A/C does not work. It’s coming apart. Can I replace the A/C compressor?
Friday, April 5th, 2019 AT 2:01 PM
Unfortunately these compressors are just very different and are not interchangeable. They will not bolt up in the Honda's location nor will the belt be aligned so it will not stay on when the engine is turning.
I am attaching the process on how to change the compressor from the manual. Please review the material below.
Also, here is a guide on how to replace the compressor which should help as well:
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Thanks
Wednesday, December 16th, 2020 AT 2:33 PM
CSCOX
  • 2002 HONDA ACCORD
  • 4 CYL
  • FWD
  • 95,000 MILES
I have a blown hose and filter requiring replacement (approx $700). My mechanic is recommending I also replace the compressor since it will save me money in the future IF the compressor breaks down. Can you provide any information on the likelyhood of the compressor going out any time soon.
Thursday, December 17th, 2020 AT 9:14 AM (Merged)
  • 31,937 POSTS
Hi there,
I would be replacing the hose and filter, then charging the system and checking the system pressures if all is ok, I would not touch the compressor as the chances of a failure are some what slim.
Mark (mhpautos)
MAREKG
  • 2002 HONDA ACCORD
Your site is wonderful and down the the point. I have 2002 v6 Accord sedan 114K miles, which has been working wonderfully until this spring. The AC unit has never had any problems. During winter I always had AC button Off, but with the warmer months coming, I figure I try it out. Turning AC button ON or setting to Auto on the console has the fan working properly without having the air cooled. I checked the compressor - it simply does not turn it self on at all. I checked the fuses - all working. I checked the computer with my little autoxray device - no fault codes at all. I checked for loose wiring or connectors unplugged - everything seems to be in place.
Again, heating and the fan work fine, but the compressor does not even budge when turn AC on. Perhaps you may advice me regarding next 2-3 steps I should undertake. Your help is sincerly appreciated.
Sincerely,
Marek
97 SEXY HONDA GURL
  • 5 POSTS
The same thing happened to my car, I had to purchase a new a/c compressor and a new a/c belt. When it freeze up like that it's nothing you can do. I spent all together about $500.00. Now my a/c works like a charm. You may want to have your mechanic take a look to see if yours is frozen. :D
MAREKG
Thank you honda Gurl. I presume that when you mentioned your car the compressor was figure of speech frozen (as in motion, unable to move). I have not had my compressor working this warmer season at all.
I am willing to take a shot this weekend to see if perhaps the relay switch at or going into the compressor is an issue. Perhaps the clutch in the compressor is a problem? In any case, thanks for the advice and sharing your experience.
Sincerely,
Marek
2CARPRO JACK
  • 11,533 POSTS
The simpler route is to be sure it has enough 134a in it to turn on. There are pressure switches that wont let the comp engage unless there is enough pressure
XBIRIS
  • 17 POSTS
  • 1999 HONDA ACCORD
  • 2.3L
  • 4 CYL
  • FWD
  • 158,000 MILES
I'm replacing the compressor & it was recommended I also replace the expansion valve & filter drier. Is this necessary? If so, where is the expansion valve located? I've found the filter drier, but not the expansion valve.
Are there any hints or tips for replacing the compressor? Thank you for any & all help!
Thursday, December 17th, 2020 AT 9:31 AM (Merged)
HMAC300
  • 48,601 POSTS
Yes it is necessary as well as back flushing your a/c system form orfice to compressor to get all the debris out. It's also imperative to pump the system down with a vacuum pump for at least 30 minutes
LPESEK123
  • 1999 HONDA ACCORD
  • 6 CYL
  • FWD
  • 220,000 MILES
My A/C compressor went out while driving. I flushed the system using flush solution and compressed air, replace the Dryer, Cycling Switch, Expansion Valve, and Compressor with a remanned compressor. After charging the system, the compressor clutch would not engage. After swapping relays, checking all fuses, and power to all points, the only way to get the clutch to engage was to jump the relay contacts. I replaced the compressor again and the same problem existed. The low side showed up to 110 psi without the clutch engaged and would only get down to 45-50 psi with clutch jumped at the relay. The high side would get up to 210 psi with clutch jumped. The clutch will not engage unless jumped. Any idea what is going on? Do I need to go to a new compressor? It is still hot in Texas and my daughter sure would like some A/C again (so would I).
KHLOW2008
  • 41,814 POSTS
Hi lpesek123,
The compressor relay is activated by a ground from the PCM and if the relay is not being grounded, you need to check the PCM.
You seem to have overcharged the system slightly.
PKVENICE
  • 1995 HONDA ACCORD
  • 4 CYL
  • 136,000 MILES
How do you replace a ac compressor on 1995 honda accord.
Thursday, December 17th, 2020 AT 9:33 AM (Merged)
Disconnect negative battery cable. Discharge A/C system, using approved refrigerant recovery/recycling equipment. If equipped with 4-cylinder, remove alternator and power steering pump (leaving hoses connected to pump).
Disconnect condenser fan connector. Disconnect compressor clutch coil connector. Remove condenser fan shroud. Disconnect suction and discharge hoses from compressor. Cap the fittings to keep moisture and dirt out of system. Remove compressor bolts and compressor. To install, reverse removal procedure. Evacuate and charge system
SECONDFRET
  • 1994 HONDA ACCORD
  • 132,200 MILES
Ok my compressor clutch would not turn on so I ran a jump wire to it and it fired right up, also checked freon with gauge and it read fine cold air began to flow. Soon as I took off jump wire it turned right back off. Also I have noticed my compressor fan would come on when I hit the a/c switch(when a/c still would not come on), now I can hit the a/c button as many times as I want and fan does not come on. Also I have noticed the cooling fan will not come on. I've ran jump wires to both and they both run fine so I know its not the motors that are bad. I changed out thermostat and coolant temp sensor and still nothing.I have checked relays and they click when jumped and I have checked fuses to the best of my knowledge and they seem fine. Can u please help me
KHLOW2008
  • 41,814 POSTS
Seems like a fault with the A/C clutch relay. Relays clicking does not necessarily mean they are good. The coil for working the relay is good but the contacts for power transfer to the clutch relay could be bad. Try swapping the relays first.
MAXIMILIAM
  • ADMIN
  • 436 POSTS
Reply from Secondfret via e-mail:
Ok I check each relay with a light up checker and they both click and light up my light. So I got curious and checked for power to the switch that goes to the relay and nothing. Turned on the car and still nothing so I piled off the relay to the other plug and checked it and it had power to I pulled the plug for the fan on the same side, same wiring harness and nothing. Do u think my harness went out or do u think the problem is the a/c button it's self. It lights up when pressed but I was reading something about right behind the button is some sort of another relay do u think that could have burned out
KHLOW2008
  • 41,814 POSTS
When ignition is turned on, power to the rrelay should be available when A/C switch is operated. If you are not getting power from the switch, test the switch, if power goes in and does not come out, the switch is bad.
VIZUAL770
  • 1992 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 203,000 MILES
The after market header that I purchased will not clear the a/c compressor. The a/c doesn't blow cold, and I live in denver anyway. Is removing the compressor reasonable? Aside from a reclaimer, what would I need? Will I need to aquire a shorter serpentine belt? And if so, where could I find one?
Thursday, December 17th, 2020 AT 9:34 AM (Merged)
F4I_GUY
  • 3,302 POSTS
If you don't plan on using the a/c ever again, just remove the compression. It's 4 bolts and 2 lines. I would try and plug the lines as best as I can, if you ever want to use the system agian.
PTERRELL
  • 1990 HONDA ACCORD
  • 4 CYL
  • FWD
  • 140,000 MILES
Took it into the shop about a rattle. Its the AC Compressor and they want $1400 to fix it. Is it possible to do it on my own? If so what do I need and how do I do it?
Thursday, December 17th, 2020 AT 9:35 AM (Merged)
