2006 GMC Sierra AC blower motor
CARLLEBLANC
  • 2006 GMC SIERRA
  • V8
  • 70,000 MILES
My 06 GMC trucks ac blower motor is acting funny. First the high speed stopping working, now the blower works every now and than like when it just won'ts to. I have been told that it could be the resistor. Could this be the problem and were and how can I check it out.
Carl
Do you
have the same problem?
Monday, February 15th, 2010 AT 4:17 PM
HMAC300
  • EXPERT
You need to disconnect the wire going to the blower and put a test light there to see if it is getting power on each part of the switch. If it does then it' s the blower, if not then you need to check your switch to see if that is sending the power to the resistor. If it does then it's probably the resistor. It is a rectangular block that isn't easy to change, as it right by the blower motor.
Monday, February 15th, 2010 AT 5:15 PM
Recommended Guides
