Change fuel filter?
MILTON6828
  • 2001 KIA SPORTAGE
Change fuel filter 2000 kia sporta
Sunday, February 6th, 2011 AT 12:03 AM
KHLOW2008
  • 41,814 POSTS
This guide will help walk you through the steps with instruction in the diagrams below for your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Removal & Installation
1. Release fuel system pressure. Locate fuel filter, on frame rail, right side of engine. Disconnect fuel hoses from filter. Remove fuel filter
and bracket.
2. To install, push fuel hoses onto fuel filter. Secure hose clamps/connectors. Install fuel filter and bracket. Tighten bracket fasteners to specification. Operate vehicle and check for leaks.
Monday, February 7th, 2011 AT 1:07 PM
LUCELLA44
  • 2001 KIA SPORTAGE
  • 4 CYL
  • 94,300 MILES
We tried to work on the fuel filter of my 2001 Kia Sportage today, but apparently we need a special tool to open it. We were able to remove it from the fuel line, but the tool is needed for us to go further. Been to Autozone, etc. Been online to various repair forums and most say it's a simple plastic tool I need. One person said he bought a tool for a different filter and filed it down to fit.
I know the tool goes and I'm supposed to depress tabs with it and push in towards the filter to open it. I cannot find anything about the tool I need, though, aside from what I've mentioned, and the two auto stores I visited today were no help at all.
If anyone can explain or tell me about the kind of tool I need, I'd appreciate it. If it is something I can get at an auto store, I'd prefer to go there than to a Kia dealership, where prices are out of this world for parts/tools/repairs, etc. Thanks for any help you can give me.
Friday, October 16th, 2020 AT 1:28 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Should look similar to one of these below and check autozone's website. contact them online and request a parts specialist to assist you to ensure you get the correct size for your filter..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1445.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_2_76.jpg
LUCELLA44
Photos are exactly what I needed. Thank you.
PRETTYWOMAN9022
  • 2000 KIA SPORTAGE
Engine Performance problem
2000 Kia Sportage 4 cyl Two Wheel Drive Automatic
Where is the fuel filter located?
  • 110,144 POSTS
It is at the rear of the engine. Here is a picture:
https://www.2carpros.com/forum/automotive_pictures/249084_fuel_3.jpg
Let me know if this helps.
CJB1865
  • 1999 KIA SPORTAGE
Can't remove fuel filter line from the fuel filter in my 1999 kiia sportage. It appears to be stuck
If its hoses on the fuel filter-cut the hose off and get a high pressure fuel hose-if not you probably need a quick disconnect tool-
CJB1865
Had the tool, actually 2 different style tools; one plastic, scissor type and the other more like a split rachet. Anyway, after trying both tools, and almost 3 hours of pinching and tugging and twisting, finally was able to remove. Oh forgot, took a straight saw and cut the 1"-1 1/2" lead from the old filter first. The main problem was "NO ROOM TO WORK" much too compact for large hands. Good News though; new pump is in and vehicle seems to be running ok!
Glad that you got it going again-Good Luck
Friday, October 16th, 2020 AT 1:29 PM (Merged)
TATTS20
  • 5 POSTS
  • 1999 KIA SPORTAGE
  • 4 CYL
  • MANUAL
Where is the fuel filter located on a 99 kia sportage
  • 31,937 POSTS
The filter is located at the rear of the engine, unfortunately we are unable to upload any pics at this time.
Mhpautos
TRAVISS
  • 1998 KIA SPORTAGE
  • 140 MILES
I just need to know where the fuel filter is located.
CJ MEDEVAC
  • 11,003 POSTS
Let's look in the engine compartment, near the fuse box.
Posted a picture/diagram below.
Here is a link that could help too:
Return here with good news!
The Medic
SHORDO1960
  • 1997 KIA SPORTAGE
  • 4 CYL
  • 171,000 MILES
Where's it at and how do I replace it.
**The high pressure fuel filter is located in the front passenger side engine compartment, adjacent to the fuse box.
**The low pressure fuel filter is located inside the fuel tank together with the fuel pump assembly.
1. Depressurize the fuel system. Refer to Fuel Pressure Release.
See: Fuel Pressure Release
2. Disconnect the fuel hoses from the fuel filter.
3. Remove the fuel filter and bracket.
Installation
When installing the fuel filter; push the fuel hoses fully onto the fuel filter.
1. Install the fuel filter and bracket.
*Tighten the bolts to 95 lb-ft (129 N.M).
2. Connect the fuel hoses to the fuel filter.
3. Connect the fuel pump connector.
