Headlights not working
SHEREF
  • 2009 NISSAN SENTRA
  • 94,000 MILES
I have a problem only in the low beam light only at the drivers side it is not working, however the high beam is fine.
Wednesday, July 19th, 2017 AT 10:08 AM
HMAC300
  • 48,601 POSTS
Check fuses in picture. if not that then do a CAN scan for codes as it may be a body module problem. Here is a video that shows how.
https://youtu.be/InIlnsjOVFA
You can get a CAN scanner for $40.00 on Amazon
Wednesday, July 19th, 2017 AT 3:40 PM
SHEREF
I checked and replaced the fuse but nothing changed
Monday, July 24th, 2017 AT 8:25 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,110 POSTS
There are several fuses and relays that work the system. Here are some guides and diagrams (Below) that will help you get the problem fixed.
and
and
Please run some tests and get back to us we are interested to see what it is.
Cheers, Ken
Monday, July 24th, 2017 AT 7:13 PM
SHEREF
  • 94,000 MILES
First the left side low beam did not work although the high beam is working. I checked the fuses they were fine. Now the tail light on the left side is also not working at all.
Monday, August 7th, 2017 AT 3:53 PM (Merged)
REY-GTS
Thanks for this post I had this problem and had to get a new IPDM which cost $176.00 all fixed I love this site.
Tuesday, November 5th, 2019 AT 2:57 PM
JFF_KOCH
  • 2002 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 10,300 MILES
Both low beams not working. Left and right headlights are fused separately (under the hood), fuses are good, and high beams work. Bulb APPEARS to be a single unit for both beams. Could this be a faulty switch, and if so, do I need a pro to replace it? Also, fog lights work but go out with high beams on. Is this normal?
Tuesday, November 5th, 2019 AT 2:59 PM (Merged)
JFF_KOCH
I bought one headlight and replaced it on the left side - it worked. I tried it right side - it worked. Although the light APPEARS to be a single unit it actually has separate elements for low and high beams. Turns out both headlights failed at the same time! Replaced both - works fine, $36.00 fix.
