Today I stopped at autozone and had them pull error codes for me. The printout doesn't list the code, I think it was p0300. Here is what it says.
Cylinder misfire detected- random cylinders
the powertrain module monitors the crankshaft speed and has detected a misfire condition.
1. Ignition system fault-spark plug(s), ignition wires, coil. (I assume this means tuneup time.)
2. Vacuum leak.
3. Injector fault.
4. High or low fuel pressure. (I assume fuel pump)
Wednesday, July 22nd, 2009 AT 8:33 PM
