2001 Ford Taurus Won't start
SHADOWMAN98
  • 2001 FORD TAURUS
  • 6 CYL
  • FWD
  • 150,000 MILES
My daughter's car overheated the other night and shut off, now it won't start. The engine cranks over and wants to start but does not start.
Monday, November 2nd, 2009 AT 11:48 AM
Do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
If both fuel pressure and blue spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain
Monday, November 2nd, 2009 AT 12:42 PM
