2000 Ford Taurus Won't start
MSJOHNSON10764
  • 2000 FORD TAURUS
Engine Mechanical problem
2000 Ford Taurus 6 cyl
Car won't start. Tried jumping it - nothing. All it does is click. I am wondering if its the starter.
Sunday, January 31st, 2010 AT 2:04 PM
No crank condition:
Possibilities here could be the starter, starter relay, park and neutral switch/clutch switch and ignition switch assuming the battery and connections are good.
Sunday, January 31st, 2010 AT 2:10 PM
MERLIN2021
  • 17,250 POSTS
If you hear a click, then either the battery is weak, or the starter, possibly bad battery cable connections, check and clean both ends of BOTH cables! Dissconnect negative(-) first, and put it on last! If no click the starter relay is no good!
Sunday, January 31st, 2010 AT 2:12 PM
