1999 Ford Taurus wont start
HEIDILINUS
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 217,000 MILES
Car will start and run until it gets hot then will stall and not start again until it has cooled down for a long time
Saturday, April 3rd, 2010 AT 2:35 PM
Next time it happens don't wait for nothing-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Saturday, April 3rd, 2010 AT 3:03 PM
