1999 Ford Taurus Wont start
JANANOW
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 14,500 MILES
The battery tested out fine, accessories work, but the engine won't turn over. Any ideas?
Thursday, April 30th, 2009 AT 12:08 PM
BMRFIXIT
  • 19,053 POSTS
Was the starter checked
check small S terminal and wire at the starter should have battery power when ignition switch in start position
if you do have power suspect bad starter
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, May 3rd, 2017 AT 11:47 AM
ATKAPARKING
  • 64 POSTS
Also check all fuses and inspect power leads coming from battery and where they join the fuse block.
