1999 Ford Taurus PLEASE HELP!
PSAVERCOOL
  • 1999 FORD TAURUS
Engine problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 10300. Miles
THIS CAR BELONG'S TO MY DAUGHTER SHE IS 16, WE BOUGHT IT AND IT RAN FINE, WE PARKED IT FOR 2 MONTH'S NOW IT WON'T START. BOUGHT A NEW BATTERY. PUT IN DRY GAS. CHECKED FUSES JUST WON'T START. ANY IDEA'S PLEASE HELP
THANK YOU PATTY
Tuesday, January 8th, 2008 AT 12:27 PM
SERVICE WRITER
  • 9,123 POSTS
Hi Patty,
What happens when you turn the key?
Nothing?
If so, check the battery connections carefully.
Are the lights bright when you turn them on?
OR
IT turns over but doesn't start?
Wednesday, May 3rd, 2017 AT 12:00 PM
PSAVERCOOL
  • 5 POSTS
Thank you for your help but I did put a new battery in it and everything is working, light's are bright, all the bell's and whistle's are working it's just not starting! Please anything you can think it might be would save me.
Thank you----patty
SERVICE WRITER
  • 9,123 POSTS
I have to assume it is NOT cranking, therefore nothing happens when you turn the key to the crank position.
Since it has been starting and cranking fine prior to the 2 month rest, I would first try to rap on the starter motor several times and see if it cranks then. Since there are moving aprsts in the starter, it may just be temporarily seized.
PSAVERCOOL
  • 5 POSTS
Thank you I will have to try that and see if it work's. By the way where is the starter located? Sorry I know I sound just like all the other woman ha! Ha!
Thank's patty
SERVICE WRITER
  • 9,123 POSTS
I need the 8th digit of the VIN on the car.
This is not cranking right?
PSAVERCOOL
  • 5 POSTS
The car crank's just seem's to not have any spark.
It was parked for 2 month's it's my daughter's car and she is now a legeal driver so I wanted to get it all toghter for her and as I said it did run wonderful before it was parked.I put in a new battery, checked all the fuses, sprayed 2 shot's of starter fluid in the fuel injecter, still nothing. When I turn the key everything work's it's just not starting at all. I thought it might be the plug's and wire's. I mean it truly want's to start. There's no problem with it not cranking because it is just not firing. I was told by a man at a garage it would be safe to spray starter fluid in the injecter just no more then 2 shot's I hear the fuel pump kick in so im lost but I wanted you to know everything that has been done to it so far.
Thank's patty
SERVICE WRITER
  • 9,123 POSTS
That was what I was looking for, this is diagnose no start, which is different than diagnose no crank.
I assume you mean the throttle body is where you sprayed the fluid. So it "sounds" like we are dealing with a lack of spark issue. Since it was working prior, I waould bo after a connection problem. The bad news is is may be on a ciruit that controls both fuel and spark.
Pull a spark plug out and get a look at it and describe it after you crank it a few times, is it white, black, wet etc.
Also have someone turn the key to the on position, not cranking and listen to the area where you put the gas in, do you hear a hum?
Check the reset button for the heck of it, typically in the trunk on the left rear.
Still need the VIN's 8th digit.
One worry is the possibility of a rodent chewing wires.
PSAVERCOOL
  • 5 POSTS
It's me again, this car is making me crazy! I did what you said and still nothing it has spark and lot's of crank but still nothing. Is it possable it might be a relay for both the fuel pump and spark plug's? Will get you the 8th digit to vin keep forgetting.
Thank you----p
