Thursday, January 7th, 2010 AT 9:28 AM
Hello, hopefully someone can help me. This car runs good when it starts, however, when it doesn't start what it does is it will crank normally but it doesn't start. All lights on dash come on like normal and the engine turns over like it does during a normal start but the it won't fire up. But it doesn't do it all the time. It will also die while driving without warning as if someone just turned the key off. I mean all lights and everything will come on dash like it normally does with key in start position but it's just that quick the rpms drop to zero and the car dies. The check engine light isn't on either. After the vehicle dies or when it has one of it's no start issues if you sit there with the key in the on position for a few minutes sometimes it'll start right up, sometimes it won't. Generally though after a bit it'll start. But the problem has seemed to get progressively worse. Thanks in advance for any help.
