It will crank but it won't start there is no fire from the spark plug wires when starting I replaced the ignition coil
Wednesday, July 15th, 2009 AT 2:49 PM
MECHANIC
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
