1993 Ford Taurus won't start
AJAMES57
  • 1993 FORD TAURUS
  • 6 CYL
  • FWD
  • 178,000 MILES
I drive a 93 ford taurus and it will not start. The starter is trying but it just won't start. The battery is old but not the problem. I had trouble starting it before work the other day went out at the end of my shift and it wouldn't start up.
Thursday, January 7th, 2010 AT 5:25 PM
Cranks and w/n start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Thursday, January 7th, 2010 AT 6:16 PM
