The crankshaft sensor is called a hall effects sensor which is located inside the distributor. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Image (Click to make bigger)
SPONSORED LINKS
Friday, March 1st, 2019 AT 2:08 PM
STHOMAS0301
MEMBER
1995 FORD TAURUS
1995 Ford Taurus
We bought this car used and it drove perfect for about three months. Daughter parked it in the driveway and it won't start again.
Several people have told us it sounds like the crank sensor. We have the part but have been told to look in two different places in the engine. Where is it located?
Saturday, March 2nd, 2019 AT 11:43 AM
(Merged)
BMRFIXIT
MECHANIC
1- looking for a crank sensor?
What do you have for an engine size
(Merged)
STHOMAS0301
MEMBER
The engine size is 3.0
(Merged)
BMRFIXIT
MECHANIC
Do not have a crank sensor
do you have a distributor ]and if so no need for crank sensor
have a pick up coil and module
if no spark check and suspect module
SPONSORED LINKS
(Merged)
STHOMAS0301
MEMBER
Thank u so much for ur help. We r going at this pretty much blind. Where is the module. Ur right, no fire.
(Merged)
TOJO PHILLIPS
MEMBER
1995 FORD TAURUS
1995 Ford Taurus 6 cyl Two Wheel Drive
where is the ignition switch located and will it kill the fire to the motor when it heats up then start back when it cools off. Help going crazy. Also will a crankshaft sensor heat up and not fire then cool off and fire? Im losing fire when the motor is at normal temp.
(Merged)
BMRFIXIT
MECHANIC
Bolted on side of the distributor
(Merged)
MECHANIC
The switch is at the bottom of the steering column. I doubt that is the problem. Has the check engine light come on? The crank sensor could be the problem.
(Merged)
BMRFIXIT
MECHANIC
(Merged)
TOJO PHILLIPS
MEMBER
No the check engine light does not come on
it has a new ignition module a new coil still losing fire should I try a new crank shaft sensor
(Merged)
MECHANIC
That could be the problem. Have you checked wiring to make sure everything is tight, clean, and not corroded or damaged?
SPONSORED LINKS
(Merged)
TOJO PHILLIPS
MEMBER
Could it be the camshaft sensor nothing dirty or lose what sensor would you put on next
(Merged)
MECHANIC
I would check the crank sensor next.
(Merged)
DROLDAN
MEMBER
1 POST
1995 FORD TAURUS
Engine Performance problem
1995 Ford Taurus 6 cyl Two Wheel Drive Automatic
where can I find the crank sensor on this car I had replace the trans and now it wont start
(Merged)
BMRFIXIT
MECHANIC
CKP sensor is located on front cover near crankshaft pulley. Disconnect negative battery cable. Remove serpentine drive belt. Raise and support vehicle. Disconnect sensor connectors.
Remove sensor bolt and sensor.
(Merged)
TABJR
MEMBER
1993 FORD TAURUS
6 CYL
FWD
AUTOMATIC
200,000 MILES
Were is crankshaft senor on eng.
(Merged)
SATURNTECH9
MECHANIC
First of all thank you so much for your donation. What is the 8th digit of your vin?Let me know so I can get you the correct information.
(Merged)
TABJR
MEMBER
Were is crankshaft sonor on eng. You ask for 8th# in vin #4
(Merged)
SATURNTECH9
MECHANIC
If the 8Th digit is a 4 then you have a 3.8L engine?If you have the 3.8L that has a distributor and wouldn't have a crank sensor. So do you have the 3.8L engine?If you don't then what engine do you have?Do the spark plug wire's go straight from the coil to plug's?Or do you have a cap the wire's come off?
