HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
General
Noises
Squeal
1999 Ford Ranger squeals when engine first starts and when
HHENLEY12
MEMBER
1999 FORD RANGER
4 CYL
2WD
MANUAL
126,000 MILES
Does it need oil. Freon. Clutch.A/c blows semi cool but not cold also compressor kicks on and off
Wednesday, January 23rd, 2008 AT 11:40 PM
MECHANIC
Could be the belt for the compressor loose-check it-Not that cool could be that it needs Freon also
Thursday, January 24th, 2008 AT 5:43 AM
Please
login
or
register
to post a reply.
Related Noise Squeal Content
1999 Ford Ranger Squeals
When Cold Sounds Like Crack In Ring Gear Had Transmission Checked By Aamco Found Nothing Wrong, Suspect Main Bearing Failure But Sound...
Asked by
williamj
1 ANSWER
1999
FORD RANGER
Squealing Sound Driver Side Rear When Flooring...
2004 Ranger Has A Squealing Sound Coming From Driver Side Rear When I Floor The Accelerator And Ceases When It Kicks Into Gear. Took It Into...
Asked by
Southpaw3612
2004
FORD RANGER
1998 Ford Ranger Engine Makes Very High Squealing...
The Engine Makes A Very High Squealing Noise At Different Throttle Settings. Also The Radiator Reservoir Looks As If It Has Just Brown Water...
Asked by
cclefty61
1998
FORD RANGER
2004 Ford Ranger Squeal In Rear Of 2004 Ford Ranger
Recently Began To Experience Squealing Noise That Seems To Be Coming From The Rear Of My '04 Ranger. Noise Begins Around 25mph And...
Asked by
JanZizka
2004
FORD RANGER
2002 Ford Ranger Truck Squeals Then Sputters And...
I Have An 02 Ranger Edge 3.0l V6 Recently Started Having An Issue Where I Would Be Driving The Motor Would Make A Squeal The Sputter And Try...
Asked by
KDUB5353
1 ANSWER
2002
FORD RANGER
VIEW MORE
Grinding Noises
Howling
How to Read Codes
