1995 Ford Mustang DRIVER SIDE ELECTRIC SEAT
DANTEER1
  • 1995 FORD MUSTANG
  • 6 CYL
  • 160,000 MILES
I CAN NOT GET MY DRIVER SIDE ELECTRIC SEAT TO MOVE BACK AND FORWARD. WOULD IT BE THE ELECTRIC MOTOR, TRACKING OR A FUSE OR RELAY AND WHERE ARE THE FUSE OR RELAY LOCATED ON 1995 FORD MUSTANG
Do you
have the same problem?
Wednesday, March 19th, 2008 AT 11:06 PM
KOOLDUDE0788
I had the same problem on my 95. First check the fuse (Under the hood *Power distributer box*) then lube everything that moves under there. If its still doesn't work its a small plastic gear that is broken. Some genius decided to use really cheap plastic gear thats smaller then a penny to move a 130 lbs + person. Mine would just tweak left and right so the best thing to do is just go to a junk yard and replace the bottom.
Sunday, April 27th, 2008 AT 10:08 PM
Recommended Guides
