Question for a friend.
JAY_C911
  • FORD F-150
I work with a Deputy that has a 2005 f-150 5.4 triton v-8 xlt 4wd and is having a problem with his truck shutting off when the wheel is turned all the way to the right and it also done it to him when he stopped immediately. When his truck idles the rpms fluctuate up and down.
Do you
have the same problem?
Wednesday, May 10th, 2006 AT 12:30 AM
PEPPERMRJ
Check for vacuum leaks. Look at the elbow for the PCV valve. They like to turn to mush.
Good luck and let us know. :)
Wednesday, May 10th, 2006 AT 9:21 PM
WITNESS7
I believe that year has a idle control sensor. I would guess that is his problem.
Thursday, May 11th, 2006 AT 8:57 PM
PEPPERMRJ
Two good reads on the subject.
http://www.2carpros.com/first_things/car_surges.htm
http://www.2carpros.com/first_things/car_dies.htm
Let us know. :)
Friday, May 12th, 2006 AT 11:12 AM
Recommended Guides
