1989 Ford F-150 Key cylinder won't engage starter
SAILOR
  • 1989 FORD F-150
  • 6 CYL
  • MANUAL
  • 130,000 MILES
This is very similar to a message a few days ago regarding ignition switch.
The switch seems to work in each position, but the key cylinder does not engage starter or return from the "start" position.
Is this likely the switch or the device that attaches to the rod going from the key cylinder to the switch?
If the latter, how do you replace it - possible part # 3E717?
Thanks.
Saturday, December 29th, 2007 AT 10:41 AM
MERLIN2021
  • 17,250 POSTS
Remove the column covers, remove neg batt cable then see if the switch, the white plastic part that rod goes to is positioned correctly, the small screws may have loosened up and now need to be adjusted and tightened. If they are not loose replace the switch!
Saturday, December 29th, 2007 AT 10:46 AM
