Tac module?
JIM PRICE
  • 2006 FORD F-150
  • V8
  • 50,000 MILES
Was driving down the road and suddenly had no acceleration, just idle speed. Shut engine off and restarted and it worked fine. Local mechanic said it was TAC module. Local Ford dealer parts department says they don't have a listing on TAC module. What part are we looking for and where does it go.
Tuesday, December 14th, 2010 AT 1:59 AM
  • 108,269 POSTS
This is the throttle actuator which the TAC module is on the side of here is how you service the unit so it will work again.
Monday, February 14th, 2011 AT 12:34 PM
TURBOJAY
Thank you for this post I had this problem and the guide fixed it I love this site.
Friday, August 16th, 2019 AT 12:50 PM
BONNIE5511
  • 2005 FORD F-150
  • V8
  • 42,000 MILES
My husband has an extended warranty for this vehicle. They told us that the throttle body assembly is not covered. Well i'm not sure.
Does this have anything to do with fuel injectors?
Please reply.
Thank you,
bonnie toups
Friday, August 16th, 2019 AT 12:51 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
No, the injectors are seperate parts from the throttle body. What is the matter with the truck that it needs a throtttle body?
BONNIE5511
My husband was at a red light and when he accelerated, the truck killed. We brought it in, thinking it was under warranty, and they told us that it was the "throttle body assy". He puts Shell gas in the truck, not the cheap gas, and I can't believe he is having this problem. When the truck is diagnosed, is there a print out that you know of that actually states what the issue is (from some machine)? I appreciate your feedback!
Thanks,
Bonnie
2CARPRO JACK
  • 11,533 POSTS
There should be atrouble code that starts witha "P" like (P0300) that isnt the code, just an example. Get that code. It is a littel odd that the throttle body is keeping it from running at all, they usually have idle issues or wont accelerate when that is an issue
BONNIE5511
Correction. My husband said that his truck killed as he was stopping for a red light. I believe I stated he was taking off from a complete stop. Sorry. Does this change your response to me? When I asked Ford about the code, she said that they had no printer to print it out. Could that be true? Is there a way for them to retrieve that code as proof they ran the code? I know I sound stupid but believe me, my husband would rather pay than to investigate.
Thanks,
Bonnie
SAULPND
  • 1989 FORD F-150
  • V8
  • 130,000 MILES
Where is the throttle body and ica motor located at on a 1989 ford f-150 pickup truck?
Thank you very much,
saul pineda
BLACKOP555
  • 10,371 POSTS
I can help you with that, the throttle body is located where the air cleaner hoses meet the intake manifold, it also hold the tps, IAC, and it is where the throttle cable hooks, it should have a little plastic shroud over it.
The iac module if I remember right is located on the right hand side of the throttle body, it is mounted onto the throttle body.
LEVI1120
  • 2002 FORD F-150
  • 4.2L
  • V6
  • MANUAL
  • 145,000 MILES
I want to know if my engine is throttle bodyed or fuel injected. Im just not sure if I need on ore 6 new injecters
Friday, August 16th, 2019 AT 12:53 PM (Merged)
HMAC300
  • 48,601 POSTS
Have it scanned for codes an dfuel pressure checked with a gauge, it is probably something else. You have 6 fuel injectors.
