2003 Ford Explorer Cuts off in drive
TRICIASUBERO
  • 2003 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 10,200 MILES
My truck will start and run fine in park, but the O/D off light comes on and whne I shift ti drive, it completly cutts off.
Do you
have the same problem?
Tuesday, September 28th, 2010 AT 7:49 AM
  • EXPERT
It sounds like the torque converter isn't disengaging the engine / trans. If the light is on, you need to have the computer scanned to make sure where the problem is coming from. Since the vehicle isn't driveable, contact the local nationally recognized parts stores and see if they will lend or rent a scanner to you.
Let me know what you find.
Friday, October 1st, 2010 AT 1:46 PM
Recommended Guides
