Overdrive light flashing?
NIGHTRIDERPLYR
  • 2007 FORD EXPLORER
  • 4.0L
  • V6
  • 116,000 MILES
My overdrive is blinking?
Wednesday, February 13th, 2019 AT 11:55 AM
  • 52,797 POSTS
Good afternoon,
Does the transmission work correctly?
If it does the light in the handle could be the issue.
If it does not, it may be the wiring to it or a transmission issue.
Are there any codes stored?
Wednesday, February 13th, 2019 AT 1:25 PM
NIGHTRIDERPLYR
Thanks for the response, there are no codes showing. In the mornings when transmission is cold, it does not what to shift into overdrive, but after driving for about a mile and a half it shifts smoothly the rest of the day. Truck shifts smoothly other than that.
Wednesday, February 13th, 2019 AT 3:41 PM
  • 52,797 POSTS
Got it.
I would start by changing the oil/filter in the transmission. That may take care of the morning issue.
As far as the light, it sounds like you need the stalk replaced.
Wednesday, February 13th, 2019 AT 3:51 PM
MIKEYG79
  • 2004 FORD EXPLORER
  • 4.6L
  • V8
  • 4WD
  • 154,000 MILES
The overdrive light started flashing the other day. Had them check at Jiffy Lube but they said it was a sealed trans and had to go to the dealer. They did give me the computer code which said it was some kind of pressure solenoid B. I assume that is in the transmission. I have an appointment at the dealer tomorrow to diagnose it.
The manual says that when this light flashes have the transmission serviced, which does not seem so bad but over the phone the service guy sure made it sound likely to be huge.
The service guy on the phone started telling me how much it is for a new transmission--$4000. This is making me uneasy. Does replacing the solenoid usually take care of it or is it more likely that the transmission need replacement for this car?
I don't have the $$ for a new one.
Can you give me any insight?
Thanks
Mike Guay
Monday, December 21st, 2020 AT 1:19 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,092 POSTS
Yes the trouble code is what you should go after first. The solenoids go out all the time and are not that bad to change. You will need to jack the car up safely to do the repair. Here is a guide for that.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Then you will need to drop the pan.
Also check the connection at the transmission plug for corrosion. Here are some guides for the job. To refill the transmission you basically pump fluid in from the bottom and let the excess run out.
Please let us know what happens and upload pictures or videos of the problem.
Cheers, Ken
DUNDEE628
  • 2003 FORD EXPLORER
  • V8
  • AWD
  • 90,000 MILES
Just had the car put on the road after a minor accident. Had the right front hub bearings replaced and when my husband was driving to work the overdrive light started flashing and check transmission came up. We took it to a servicer and they said it pulled the gear ratio error in gear 5. Is there anything that can be done as we do not have $2000 to have the transmission rebuilt
ED-WEEZY21
  • 248 POSTS
Unfortunately, no. Incorrect gear ratio codes and caused by internal failure and the transmission either needs to be replaced or overhauled. You can go to a junkyard and get a transmission but you always risk the chance of having that same problem. Most junkyards will give a warranty but they don't cover the labor. See if the mechanic can give you a better estimate or shop around for the best price but BE SURE to pick a reputable shop. Best of luck.
SAMKR
  • 6 CYL
  • 4WD
  • 130,000 MILES
I have a 2003 Ford Explorer(V6) and as I was driving down the highway my Overdrive light starts flashing(I was not towing anything) what could this be.
  • 108,328 POSTS
I hate to say it, but you need to have the computer scanned to identify where the problem is coming from. If the light is flasing, chances are there is a sensor issue. The only way to be sure is to retrieve a trouble code from the computer to identify which one.
NOTE: Many parts stores will scan for free; however, most of them don't have a good enough scanner to check ABS, TRANS. Codes. You will need to take it to a shop or a trans shop.
CAMILO CB
  • 10 POSTS
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 95,000 MILES
I noted that my auto trans has a delay on the shifts. I press on gas and does not respond according. The engine rpm increases and the gears delay to engage. So, I have to depress the pedal and then it engages. Also the OD light starts blinking. Sometimes, it works perfect. What should I do?
I was thinking of changing the trans fulid and filter.
Do you have the procedure to change the trans fluid? I would appreciate to have it has well.
Monday, December 21st, 2020 AT 1:31 PM (Merged)
  • 108,328 POSTS
Have you had the computer scanned?
CAMILO CB
  • 10 POSTS
Not, yet. The Service Engine Soon Light is on but I did not have a chance to retrieve the code as I had to leave home couple of days after that to work. I'll do that when I get home. Will be the first thing to do before touching anything. I hope is not serious.
  • 108,328 POSTS
Let me know what you find when you have the chance.
CAMILO CB
  • 10 POSTS
I will let you know when I get the codes.
Thanks.
  • 108,328 POSTS
Glad to help.
LINZLIBRA12000
I have an '02 exlorer and mine does the same thing I have no idea why though I will be watching your question hopefully WE can get and answer
  • 108,328 POSTS
Honestly, it could be several things causing a delayed shift. If the light is flashing, the computer needs scanned to determine where the problem is coming from.
CAMILO CB
  • 10 POSTS
I've retrieved the code and it's: P0747 (Pressure Control Solenoid A).
Now I do have another problem: After been driving like that for couple of days after experiencing shift delays, the car won't go on reverse. I tried and it went with difficulties. I parked the car and quit driving it. Also re-scanned to see if there's a new code and just says the only code which is P0747.
Is it serious?
CAMILO CB
  • 10 POSTS
Ok. The code is P0747. My idea was to change the trans fluid 7 filter before that. Now I need help on what I have to do. Where is the Pressure Solnoid A located. Just replace this solenoid or it's better to replace all at once if they're in one block/pack.
CAMILO CB
  • 10 POSTS
Is it serious?
