Tuesday, January 1st, 2008 AT 12:00 PM
My ford died on me the other day, I sent it to my wifes dads shop he put in a new fuel pump, then a pcm. Still wouldn`t run right, you turn the ignition and the fuel pump kept running and the relays under the hood were clicking. I sent it to the local ford shop, they ended up putting a new fuel pump in it. Anyway I get it home and it does the same thing the next morning when I try to start it. The symptoms are the same and when you drive it it idles really high and it will just fall in and out of gear, but if you shut it off and on several times it will run fine. Do you have any idea what is going on?
