Anti theft reset?
KAJORDAN
  • 1999 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 180,000 MILES
How to reset anti theft. Please help me.
Thursday, August 12th, 2010 AT 2:31 PM
  • 108,300 POSTS
Exit the car and lock it and let it sit for 30 minutes. Then use the fob to unlock it and it should be reset. Also you can do hard reboot by touching the negative battery cable to the positive battery terminal to discharge the capacitors. Here is a guide that can helps as well.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Thursday, August 12th, 2010 AT 10:52 PM
INUKKAZ
  • 251,000 MILES
Drove it fine yesterday and a friend played with the locks in the car now it wont turn over. Its the original key and the battery is fine in it.
Monday, October 22nd, 2018 AT 1:15 PM (Merged)
HMAC300
  • 48,601 POSTS
Have you locked and unlocked the door with the key? That usually will reset them...
Have you checked for power at the starter solenoid? May be a coincidence that the starter is bad
See the guide below on using a test light, it is a good way to check for power at the small trigger wire on the solenoid
Attached below is the wiring diagram for your starting circuit
MAXTER
  • FORD EXPLORER
I have a 1999 ford explorer 2wd 5.0 4dr.86000mi. After unlocking doors with remote alarm goes off when door is opened. This is the factory alarm system. Is there a way to diconnect the alarm altogether?
TAURUSWHEEL
  • 718 POSTS
Which system do you have, PATS or active? Or both?(Not sure if this is available). Does your key have the chip(pats)? If you have the active, make sure all your door switches and such are not hanging up, may have to have it diagnosed by knowledgeable person, this system can be checked with a scanner capable of reading pid's and so forth, also the ngs tester. There's a couple of modules, rap and gem, that also play a part in this sytem, check all the easy stuff first. You may have to have someone look at it, without the correct diagnostic routines, may be hard to figure out. Hopefully it's something simple. Does the keyless entry system still work? You can try unhooking the battery + cable and re-installing it.
MAXTER
You asked if the ignition had the chip remote-it does not. The keyless entry does work as does the panic alarm button. Just can't disarm with remote. Thankyou.
PAM249
  • FORD EXPLORER
The alarm on my 1997 Explorer goes off at odd times. Often within seconds after locking it (either manually or with the remote). Occaisonally it will go off in the middle of the night. It is kept in the locked garage so no one is messing with it. It just goes off. What could be causing this? Is it something I could fix myself or does it need to go to the dealer?
LSUSSEL
  • 252 POSTS
You can fix it yourself. You might want to turn down the senstivity on the alarm. This is not an after market alarm is it?
PAM249
How do I turn down the sensitivity? It just started doing this in the last 6 months and it's quite sporadic. It may go off 2 0r 3 days in a row and then not again for a couple of weeks.
LSUSSEL
  • 252 POSTS
Is this a custom security system, after-market?
PAM249
I think it is the original one that came in the vehicle. I am the second owner.
BOOSIEDUDE
  • 1996 FORD EXPLORER
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic
i have a 96 ford explorer. The alarm goes off in the midddle of the night without setting the alarm what do I do. I look online and they said to unplung the connector in rear kick side panel. If I unplung it the car wont start but I tride it. I unplung one and it starts and the other and it starts. Is it ok to unplung one or the other. I need Help BAD I dont Got Money To fix it.
  • 108,300 POSTS
I hate to say it, but you need to take it to a dealer. There are a few things that could cause it and they are the only ones with the proper test equipment.
PLOWY
Electrical problem
1999 Ford Explorer 6 cyl Four Wheel Drive Manual New miles
Hi
I Have been doing up a 10/'99 xl Explorer. It was badly treated and needed a new motor. Installed new motor and started it up. All good. As it sat in the shed waiting for the rest of the makeover it would intermittingly not start and then start. Took it to the auto electricians to get some wiring done etc. Turns out it needs another blinker switch combination which I got secondhand and they replaced it. They were moving the car around the yard as need be and then it would'nt start. It was no longer intermittingly and the anti - theft light was staying on while cranking over. The Electrician apparantly had the key etc. Tested and they were fine so I'm wondering if while the blinker combination switch was being replaced something happened in that area to stop the car from starting alltogether. I'm thinking of putting another ignition switch in anyway? My auto electrician is pulling his hair out and so am I as he has had the car there for a couple of months and we would all love to get to the bottom of this problem.
Hope you can help
Plowy
2CARPRO JACK
  • 11,533 POSTS
If they dont have a scanner capable of communicating with the anti-theft system, you might have to go to the dealer or another shop that can. The proper scanner can communicate with the controller to see if there is a problem with the RAP (remote anti-theft personality) or GEM (generic electronic module) or if the problem is with comm between the two
KLDAVIS3
  • 1994 FORD EXPLORER
How to disable the alarm in a 94 ford explorer? Which fuse do I pull?
WRENCHTECH
  • 20,758 POSTS
It's certainly not that simple. If you're talking about the factory engine disable, it HAS to be operational. If it's an aftermarket system, then it has to be removed and all the wires it interrupted have to be spliced back together.
DEMO_CHICK05
Electrical problem
How do I disable the alarm? I disconnected the amp and the alarm went off. The only way to shut it off now is to disconnect the battery or unplug the fuse, but not everything is working without it.
Friday, June 12th, 2020 AT 12:45 PM (Merged)
  • 108,300 POSTS
Is this a factory alarm system? If so, there really isn't any way around it. Is the vehicle even starting for you?
DEMO_CHICK05
Yes the alarm is factory. The only way to get the truck started is to remove the fuse that runs it, but now the windows won't work.
