HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Engine
Symptoms
Not Running
1996 Ford Explorer
JAZYNEZ
MEMBER
1996 FORD EXPLORER
6 CYL
FWD
AUTOMATIC
14,000 MILES
The engine turns over but will not start
Tuesday, February 12th, 2008 AT 8:26 PM
BLACKOP555
MECHANIC
Are you getting bright blue spark at all cylinders?
Tuesday, February 12th, 2008 AT 9:09 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Engine Won't Start And Run?
I Am Having Issues With My Explorer. Once The Weather Starts Getting Warmer Say Over 75 Degrees It Will Not Start. I Can Usually Go Out...
Asked by
rebabecca
1996
FORD EXPLORER
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1996 Ford Explorer Engine Cranks But Will Not Start
I Have Been Experiencing Some Problems With Starting My Ford Explorer. I'm Not Sure What The Cause Is. At First I Thought It Was The...
Asked by
rshelby11
1996
FORD EXPLORER
1996 Ford Explorer My Explorer Wouldn't Start, Now...
I Have A 1996 Explorer. We Recently Relaced The Alternator And A Belt About 3 Months Ago. I Haven't Had Any Problems Since Then Until Now....
Asked by
Kolbycheese
1996
FORD EXPLORER
1996 Ford Explorer Ignition
I Was Driving Then I Stop At A Light, I Put The Car In Neutral Turn The Ignition Off And Then Back On. It Wouldn't Start, So I Put It In...
Asked by
muadib1
1996
FORD EXPLORER
My Engine Turns Over, But Won't Stay Started. What...
My Engine Turns Over, But Won't Stay Started. What Is Likely Wrong With It And How Can I Fix It? Thanks! - Dan
Asked by
danhildebrand
1996
FORD EXPLORER
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Replacement
