HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Engine Cooling
Cooling Fan
Clutch
Replace/Remove
1993 Ford Explorer fan clutch
CHEEKS
MEMBER
1993 FORD EXPLORER
6 CYL
2WD
AUTOMATIC
175,000 MILES
How do u remove the fan clutch so I can replace coolant fan that is cracked?
Saturday, February 2nd, 2008 AT 12:14 PM
MAZDA1003
MEMBER
You need a special set of wrenches to do it. They have them at Napa for about $50-60. Otherwise, you will strip something.
Monday, February 4th, 2008 AT 11:20 AM
Please
login
or
register
to post a reply.
Related Cooling Fan Clutch Replace/Remove Content
1993 Ford Explorer Fan Clutch
Trying To Remove Water Pump Fan Clutch Picture Does Not Match One On Website Have Serptine Belt Is Nut On Front Of Pulley The One To Be...
Asked by
LeeBax
1993
FORD EXPLORER
GUIDE
Fan Clutch Removal
A fan clutch is featured on rear wheel drive cars only because it connects to the water pump and faces the radiator while pulling air through the radiator cooling fins when...
Engine Cooling Problem 1993 Ford Explorer Four Wheel Drive Automatic 156, 00 Miles I Need To Change My Water Pump And I Can Get The...
Asked by
beidson
1 ANSWER
1993
FORD EXPLORER
How Do You Remove The Clutch Fan?
Asked by
crazyjay
1 ANSWER
6 IMAGES
1998
FORD EXPLORER
Fan Clutch Replacement Instructions Please?
I Have Had 2 Fan Clutches Installed, And The Fan Still Stays Engaged A Very Long Time After I Start. I Got A New One From Ford I Want To...
Asked by
dewightb
1 ANSWER
6 IMAGES
2002
FORD EXPLORER
1996 Ford Explorer Fan Clutch Removal
Engine Cooling Problem 1996 Ford Explorer 6 Cyl Two Wheel Drive I Have The Removal Tool For The Clutch Fan.I Do Not See Where The (...
Asked by
rekey
1 ANSWER
1996
FORD EXPLORER
VIEW MORE
Engine Overheating
Is Your Engine Cool Enough to Check?
Overheating Symptoms
