1999 Ford Expedition wont start
AGUIRRE27
  • 1999 FORD EXPEDITION
  • V8
  • 4WD
  • 165,000 MILES
Was driving fine wen I turned it off, I started it up and it just cranked up but didnt start over
Friday, July 30th, 2010 AT 4:19 PM
Cranks but no start condition-do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, July 30th, 2010 AT 10:03 PM
