Serpentine belt
BLUEROSE2
  • 1999 FORD CONTOUR
  • 2.5L
  • 4 CYL
How do you replace the serpentine belt on my Contour?
Thursday, January 22nd, 2015 AT 2:16 PM
CARADIODOC
  • 33,742 POSTS
Here are some guides to help you change the belt, its not too difficult of a job
https://www.2carpros.com/articles/replace-serpentine-belt
Heres the belt diagram
https://www.2carpros.com/diagrams/ford/contour/1999
Thursday, January 22nd, 2015 AT 2:42 PM
AJMCCART
  • 1999 FORD CONTOUR
  • 4 CYL
  • FWD
The car is overheating, went to replace thermostat and found broken belt.
Tuesday, January 15th, 2019 AT 6:18 PM (Merged)
HMAC300
  • 48,601 POSTS
Thepic oi'm sending is from a 2.0 as you didnt' tell us engine size. You need to loosentensioner to get belt off and on. It is ADVISABLE to replace the tensioner at same time as belt.
HMAC300
  • 48,601 POSTS
Heres one of a 2.5 water pump
AJMCCART
Sorry about that. It's the 2.5 liter motor. Thank you for your help:)
HAZRAT001
  • 1996 FORD CONTOUR
  • 4 CYL
  • FWD
  • 167,000 MILES
What is the easiest way to change a Serpentine belt on this car your self? What tools are needed?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
Hey Hazrat001,
Just did one of these in the shop and made a video check it out.
https://youtu.be/uafIvqzDkp0
also here is the diagram routing in case you need it.
https://www.2carpros.com/diagrams/ford/contour/1996
Please let us know happens so it will help others.
Best, Ken
2CP-ARCHIVES
  • 4,542 POSTS
  • 1995 FORD CONTOUR
  • 154,000 MILES
How do I remove serpentine belt
WRENCHTECH
  • 20,757 POSTS
You have to rotate the spring loaded tensioner with one hand while slipping the belt off with the other hand.
MSSHELLENE
  • 2000 FORD CONTOUR
Four cylinder two wheel drive automatic 168,000 miles.
Please send the diagram ASAP. The engine compartment diagram is missing and my mechanic is standing here.
OBXAUTOMEDIC
  • 3,711 POSTS
Just so you know for next time, if you are in a hurry for something check out the left side bar under the Popular Site Links section Drive Belt Routing Diagrams.
Check out the link below and find your diagram.
https://www.2carpros.com/car_repair_information/year/2000/make/ford/model/contour/2000_ford_contour_drive_belt_routing_diagram.htm
JIS001
  • 3,408 POSTS
I am assuming you have A/C on this.
https://www.2carpros.com/forum/automotive_pictures/337695_belt_1.jpg
CHAOSD33
  • 1995 FORD CONTOUR
  • 4 CYL
  • 143,728 MILES
Can I bypass the A/C pump with a smaller belt? My pump doesn't turn at all and I can't afford to get it fixed.
  • 108,192 POSTS
I've heard that people remove the compressor and use a belt diagram for a non ac vehicle. Check the belt routing diagrams site under the popular site links on this page. See if it looks like it will work for you.
Let me know what you find of if you have other questions.
FORDBABY
  • 2000 FORD CONTOUR
Engine problem
2000 Ford Contour 4 cyl Wheel Drive Type unknown Automatic 89000 miles
The timing was stuck so we had to have a new timing kit put on. 150 miles later the serpentine belt broke and 2 of the 3 bolts were missing off the main motor pulley. The mechanic said he did not touch that for him to fix the timing. I was told that the belt would have to be taken off to get to the timing. Which is correct? Thank you
Renee
BLACKOP555
  • 10,371 POSTS
I dont see how he could change it with the belt on! It doesnt mean that he took off the harmonizer though, which is probably is what he meant.
