Firing order
JEFFJ
  • 1997 FORD F-150
  • 6 CYL
  • 142,070 MILES
My truck has a 4.2l. What is the spark plug wires routing? I.E from coil on top of tunnel ram to plugs.
Friday, March 11th, 2011 AT 4:47 PM
DOCFIXIT
  • 18,828 POSTS
Here is the engine spark plug firing order. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
Friday, March 11th, 2011 AT 5:00 PM
TXWILDFLOWER281
  • 1996 FORD F-150
Electrical problem
1996 Ford F150 V8 Two Wheel Drive Automatic
What is the Fifing order on this truck?
Monday, February 8th, 2021 AT 12:44 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
5.0 liter
https://www.2carpros.com/forum/automotive_pictures/1639_ford_50_1.jpg
5.8 liter
https://www.2carpros.com/forum/automotive_pictures/1639_ford_58_1.jpg
WALKER2980
  • 1996 FORD F-150
  • 6 CYL
  • 15,000 MILES
I have miss placed my plug wires on my distributor and can't get them in the right order. Can't seem to find a diagram for it. HELP!
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_49_firing_order_1.jpg
Hello, 4.9 vin Y
Verify TDC for #1 is correct on the distributor
VEGAJERRY
  • 1994 FORD F-150
What is the firing order?
BLUELIGHTNIN6
  • 16,542 POSTS
4.9L engine
Firing order: 1-5-3-6-2-4
Distributor rotation: Clockwise
https://www.2carpros.com/forum/automotive_pictures/261618_0900c152801cd424_1.jpg
Let me know if your engine is different than a 4.9L engine..
Thanks for using 2CarPros.com!
MLEEBARNES
My F150 4.9L engine has a different firing ofrder. Mine is similar to the 4.9L tempo listed on your site.
I attached all the info from the manual on timing and firing order just for your reference and others in the future. Thanks
JOELDENNIS7
  • 1994 FORD F-150
  • V8
  • AWD
  • 180 MILES
I have a Ford F150 with a 5.0L mustang Engine. What would be the firing order for that. I
Monday, February 8th, 2021 AT 12:45 PM (Merged)
Here is the engine firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
LOU SPINNER
  • 1994 FORD F-150
  • 4.9L
  • 6 CYL
  • 814,490 MILES
Do not know how to set timing.
Good afternoon.
All the information is below.
Firing order
1-5-3-6-2-4
Cap location for wires attached.
Ignition timing
INITIAL TIMING
1. Place transmission in NEUTRAL (M/T) or PARK (A/T) with A/C and heater in OFF position.
2. Connect an inductive timing light.
3. Disconnect the single wire in-line Spark Output (SPOUT) connector or remove the shorting bar from the double wire SPOUT connector.
4. Start engine and allow to reach operating temperature. With engine at timing rpm, check or adjust initial timing to specification.
NOTE: To set timing correctly, a remote starter should not be used. Use the ignition key only to start the vehicle. Disconnecting the start wire at the starter relay will cause Ignition Control Module (ICM) to revert to start mode timing after the vehicle is started. Reconnecting the start wire after the vehicle is running will not correct the timing.
5. Reconnect single wire in-line spout connector or reinstall the shorting bar on the double wire spout connector. Check timing advance to verify distributor is advancing beyond the initial setting.
6. Remove test instruments.
Ignition timing
Base Timing. 10° BTDC
AJSEXTON
  • 1991 FORD F-150
  • V8
  • 97,381 MILES
I need to know the firing order on the motor and the to install the oil rings into my truck?
BMRFIXIT
  • 19,053 POSTS
V8 5.0L
https://www.2carpros.com/forum/automotive_pictures/99387_50_and_75_1.jpg
5.8L
https://www.2carpros.com/forum/automotive_pictures/99387_58_l_1.jpg
TD MCLEAN
  • 1986 FORD F-150
  • V8
  • 133 MILES
The firing order and spark plug wire order for a 302 efi fuel inj engine if so can I get a picture or a diagram please asap.
https://www.2carpros.com/forum/automotive_pictures/12900_fo_9.gif
Firing Order 1-5-4-2-6-3-7-8
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
PUFFYSTEVEO
  • 1979 FORD F-150
Engine Performance problem
1979 Ford F150 V8 Two Wheel Drive Automatic
I need to know what the firing order is and a picture of it. I replaced the cap and rotor and boy does the truck run bad, backfires
There you go
https://www.2carpros.com/forum/automotive_pictures/12900_58912497_1.jpg
NANCY DEITZ
I need just to look at the firing order for a 1979 f 100 truck, 300-6 cylinder (anything else)
