Image (Click to make bigger)
SPONSORED LINKS
Wednesday, November 7th, 2012 AT 6:48 AM
JONNYB88
MEMBER
Thanks guys that's what I needed
Wednesday, November 7th, 2012 AT 9:16 PM
TERRYWAYNE2
MEMBER
1 POST
2005 PONTIAC GRAND PRIX
Need firing order diagram front and side view. It is a 3.8 xp Grand Prix. I think I crossed wires.
Monday, March 8th, 2021 AT 6:11 PM
(Merged)
MECHANIC
Here is the engine spark plug firing order. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
(Merged)
REDNECK0819
MEMBER
3.8L
6 CYL
2WD
AUTOMATIC
114,000 MILES
Is there a difference in the firing order of the 3800 between a VIN:K and my old ladies that is a VIN:2? The coil packs from top to bottom run 6-3-2-5-4-1. Just trying to make sure they didn't get cross wired somehow. Thank you
SPONSORED LINKS
(Merged)
DANNY L
MECHANIC
Hello, I'm Danny.
Yes, both the vin K and vin 2 firing order on the 3.8L motor is exactly the same. I've attached pictures below. Hope this helps and thanks for using 2CarPros.
Images (Click to make bigger)
(Merged)
CIRACING13
MEMBER
1 POST
1996 PONTIAC GRAND PRIX
I need the firing order diagram for the 3.1L v6
(Merged)
JDL
MECHANIC
Hi, welcome to the forum. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
(Merged)
SARAH&GREG
MEMBER
1 POST
1995 PONTIAC GRAND PRIX
6 CYL
FWD
AUTOMATIC
164,000 MILES
What is the fireing order on a pontiac grand prix gtp? It has the 3.4 dohc motor. My car starts up an revse up an shuts off.
(Merged)
JDL
MECHANIC
You treat a start and die the same as a no start. You try to out what your losing. Spark-- fuel, don't guess about the fuel, use a gage and check pressure, key on and then after it dies. any codes?
(Merged)
SHOOTOUTFAN
MEMBER
1 POST
1985 PONTIAC GRAND PRIX
6 CYL
2WD
AUTOMATIC
142,345 MILES
Whats is the location of the number 1 clynder and the firing order and the location each wire goes on the distributer?
