My engine stalls at idle why?
RHONDA HICKS
  • 2004 JEEP GRAND CHEROKEE
  • 4.0L
  • 6 CYL
  • 4WD
  • 243,000 MILES
The vehicle will start and idle. The idle is sometimes a little rough, but that bad however when I go to drop it in reverse to back out of my drive way it shuts off. My husband can give it gas while in park and you can literally see black smoke puff out.
Friday, February 1st, 2019 AT 3:55 PM
  • 108,269 POSTS
If you are seeing black smoke, chances are the engine is getting too much gas. Now, this can be caused by a few different things. First, a bad fuel pressure regulator can be bad. Next, a bad coolant temperature sensor can cause it.
With that, I need you to do the following. First, if the check engine light stays on when the engine is running, you need to scan the computer for diagnostic trouble codes. Here is a quick video of how that is done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner. If that is the case, most parts stores will scan it for free. If you have that done, let me know the codes.
Next, I would recommend checking fuel pressure and the regulator to make sure it isn't too high. Here is a link that shows how it is done:
The fuel pressure readings should be as following.
Fuel Pressure .................... 339 kPa ± 34 kPa (49.2 psi ± 5 psi)
If you find the pressure is high, the regulator has most likely failed. The regulator on this vehicle is located above the fuel tank and part of the filter. I attached a picture of it to help find it.
Check these things first and let me know what you find.
Friday, February 1st, 2019 AT 8:45 PM
RHONDA HICKS
We have decided to just put a new fuel pressure regulator on it. We ordered it and it will be here tomorrow, we do not have the tools to check the pressure and have no way of getting the car to anyone who can scan it for us at the time. Thank you for replying, I will let you know if the regulator works.
Saturday, February 2nd, 2019 AT 12:26 PM
RHONDA HICKS
We changed the fuel pump less then a month before this problem started. I do not know if we should have changed the fuel pressure regulator then. I know it is also the filter.
Saturday, February 2nd, 2019 AT 12:28 PM
  • 108,269 POSTS
Hi again:
I hate changing things without being sure. Without checking pressure or knowing the fuel trims, I don't know for sure if that is the problem. It can be, but without testing, it becomes a guess. I hope you understand.
Regardless, here are the directions for replacing one. The attached pictures correlate with these directions.
The combination Fuel Filter/Fuel Pressure Regulator is remotely mounted to the vehicle body, above the rear axle and near the front of the fuel tank.
See Picture 1
1 Perform Fuel System Pressure Release Procedure.
2 Disconnect negative battery cable at battery.
3 Raise vehicle.
4 Clean area around 3 filter/regulator fittings.
Fuel Filter/Fuel Pressure Regulator Location
See Picture 2
5 Disconnect fuel supply fuel return and fuel pressure lines at filter/regulator. Refer to Quick-Connect Fittings.
6 Remove 2 mounting bolts and remove filter/regulator.
INSTALLATION
1 Before installing filter/regulator, be sure all fittings are cleaned of all dirt and contaminants.
2 Be sure O-ring is positioned into fuel return fitting in filter/regulator.
3 Apply a small amount of clean engine oil to O-rings.
4 Position filter/regulator to body and install 2 bolts. Tighten bolts. Refer to Torque Specifications.
5 Connect 3 fittings. Refer to Quick-Connect Fittings.
6 Connect negative battery cable to battery.
7 Start engine and check for leaks.
__________________________________________________
Saturday, February 2nd, 2019 AT 9:08 PM
GDUERST
  • 6 CYL
  • 4WD
  • 57,000 MILES
Wife left the key in the on posistion for 6 hours. The car started after jumping but will not idle when in gear.
Tuesday, June 22nd, 2021 AT 5:04 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
This is common when you have a vacuum leak or the throttle bore needs to be serviced here are three guides to go over when fixing the problem.
and
https://www.2carpros.com/articles/stall-at-idle
and
MERLIN2021
  • 17,250 POSTS
You need to know if the battery is fully charged, if the volts are too low, the computer will not operate correctly. Recharge or replace the battery.
TIMMYFLAX
  • 2003 JEEP GRAND CHEROKEE
  • 114,000 MILES
Jeep was running fine last night. Never had an issue with it before, but have owned grand Cherokees before. I went to start the jeep this morning, would crank over, as if the battery was dead. I jumped the jeep with my wifes car, and after giving it a little gas, the jeep fired right up, however it would not stay running unless I was on the accelerator. I jumped it again from a friends truck, I kept on the accelerator for a minute or so at 1000RPM and had him disconnect the cables, and the jeep would stay running as long as I was on the accelerator, but if I let off it died. I have had alternator problems in the past with other vehicles, but never experienced this. I have been told that my battery may be junk which would make sense but would appreciate a second opinion. Any ideas?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,967 POSTS
This happens when the computer is trying to relearn this guide will help explain it better.
https://www.2carpros.com/articles/engine-stalls-idles-too-high-low-after-dead-or-replaced-battery
we have a new article that shows the throttle bore service step by step which can help as well.
JAMES CARLTON
  • 6 POSTS
  • 2002 JEEP GRAND CHEROKEE
  • 4.0L
  • 6 CYL
  • 260,000 MILES
Vehicle starts then immediately shuts down. I have cleaned and checked all throttle body sensors. Replaced fuel filter and regulator. Does this pretty much confirm a bad fuel pump?
  • 52,797 POSTS
Good morning,
I would check the pressure first before assuming the pump is bad. I attached the specs for you below. You can rent a tester to verify at a parts store.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Fuel system pressure 339 kPa +/- 34 kPa 49.2 psi +/- 5 psi
Check this first to verify.
JAMES CARLTON
  • 6 POSTS
Thanks for the get back. I'm on my way out to get started on the beast. Will let you know what worked.
  • 52,797 POSTS
You are welcome.
Always glad to help.
JAMES CARLTON
  • 6 POSTS
As it turned out my situation had nothing to do with security related issues.
I installed a new fuel pump and it still started up and run 2 seconds then quit. After pulling the rest of my hair out, l remembered removing the CPS along with the oil pump drive. I didn't know that little fella controlled the injector sequence. I did a reset on the timing and reinstalled everything. The engine turned 1/2 round, fired and runs like a champ.
I want to thank you men for everything you did to walk me through this. Y'all saved me my other leg. Now l know who to go to when l run into another auto problem.
Thank you
  • 52,797 POSTS
You are welcome.
Glad to help.
JAMES CARLTON
  • 6 POSTS
  • 4.0L
  • 6 CYL
  • 250,000 MILES
I was working in the steering column and unplugged the immobilizer. Since then my Vehicle will start and run about 2 seconds. What can l do about this issue without paying $300.00 for a locksmith?
  • 52,797 POSTS
Good morning,
The locksmith is the best alternative. In order to do it yourself, you will need a DRB scan tool that is very expensive to reset the system.
https://www.2carpros.com/articles/how-to-reset-a-security-system
AMBER1710
  • 2001 JEEP GRAND CHEROKEE
  • 4.7L
  • V8
  • 4WD
  • 16,000 MILES
My vehicle will start but then will shut off straight after. We changed the fuel pump, no engine check lights and the problem is still occurring. Would it be my mass airflow sensor?
Add to the post have done a full service including transmission.
  • 108,269 POSTS
Welcome to 2CarPros.
The mass air flow sensor may cause it to run poorly, but what you described doesn't sound like it. Does the vehicle start right back up after it stalls only to do the same thing?
If that is what is happening and there is no check engine light, my first suspect is the crankshaft position sensor. If the vehicle won't start after it stalls, then you can take your scanner and check if there is an RPM signal when it won't start. If there is none, then the sensor is my first suspect.
Take a look through these links:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Another way to test the sensor is by checking for ignition spark. If when the engine shuts off you note that spark stopped, the sensor is a suspect.
Here are the directions specific to your vehicle for replacing the sensor. It is located right above the starter. However to access the retaining bolt, the starter needs removed. Make sure to disconnect the battery before you work on or around the starter. The attached pictures correlate with the directions.
2001 Jeep Truck Grand Cherokee 4WD V8-4.7L VIN N
Procedures
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Crankshaft Position Sensor Service and Repair Procedures
PROCEDURES
REMOVAL
Fig.22 CKP Sensor Location
Pic 1
The Crankshaft Position (CKP) sensor is bolted to the side of the engine cylinder block above the starter motor; It is positioned into a machined hole at the side of the engine block.
1. Remove starter motor. Refer to Starter Removal/Installation.
2. Disconnect CKP electrical connector at sensor.
Fig.23 CKP Sensor Removal/Installation
Pic 2
3. Remove CKP mounting bolt.
4. Carefully pry sensor from cylinder block in a rocking action with two small screwdrivers.
5. Remove sensor from vehicle.
6. Check condition of sensor O-ring.
INSTALLATION
1. Clean out machined hole in engine block.
2. Apply a small amount of engine oil to sensor O-ring.
3. Install sensor into engine block with a slight rocking action. Do not twist sensor into position as damage to O-ring may result.
CAUTION: Before tightening sensor mounting bolt, be sure sensor is completely flush to cylinder block. if sensor is not flush, damage to sensor mounting tang may result.
4. Install mounting bolt and tighten to 28 Nm (21 ft. Lbs.) torque.
5. Connect electrical connector to sensor.
6. Install starter motor. Refer to Starter Removal/Installation.
___________________
AMBER1710
Yes that was it all fixed thank you so much!
