Installing a Dome Light?
00MAGICMATT
  • 2004 PONTIAC GRAND AM
My dome light popped off in a Pontiac Grand am 2004. How do I reinstall it if there is a black plate over the plastic to click it back in?
Tuesday, May 31st, 2011 AT 5:56 AM
  • 108,192 POSTS
You will need a small flat blade screwdriver. Check out the diagrams below.
Check out the diagrams (Below)
Cheers
Tuesday, August 30th, 2011 AT 2:58 AM
GKDJBLACKONE
  • 3.4L
  • 6 CYL
  • 160,000 MILES
How do I reinstall the dome light?
Thursday, April 12th, 2018 AT 12:33 PM (Merged)
HMAC300
  • 48,601 POSTS
See pictures on how to do it. It pretty easy to do. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
JSCOTTY78
  • 97,000 MILES
The dome light on my 2004 Pontiac Grand Am does not come on at any time unless you push up on the dome light. Could this be a bad connection? How do I fix this problem. Pain to get in the car at night as I have no light to see. Do I have to remove the entire carpeted roof panel to repair?
FIXITMR
  • 9,990 POSTS
Sounds like a bad connection or bad dome light assembly? Remove cover and see whats holding it too ceiling should be clips or screws.
ZACKD1987
  • 1997 PONTIAC GRAND AM
  • 4 CYL
  • 128,000 MILES
Im not sure if u could really solve this one but anyway. I have a 350 watt amp installed in my car but everytime the bass hits the dash lights and the dome lights do a small flicker I'm not sure if its a bad ground or what it could be.
Thursday, April 12th, 2018 AT 12:34 PM (Merged)
MHILLE
350 watt amp... 2 options... Either turn down the bass or you'll need to buy a heavy duty alternator.
https://www.2carpros.com/forum/automotive_pictures/251425_ga_sm_1.jpg
