Monday, September 20th, 2010 AT 12:51 AM
Whenever I start this truck it has a fluctuation at idle from 600 to 900 rpm, then as I put it in drive it goes normally. Thats one problem, the other is when im driving, I would give it gas and when I do, there seems to be no power at all and and w.O.T, after letting off the accelerator, it tries to die. Thinking it may be a bad map or throttle sensor or maybe even my fuel injectors. Also know that my alternator is not holding the charge it should be, so would that affect my problem also?
