2004 Dodge Neon
MEBRUESSSEL
  • 2004 DODGE NEON
2004 Dodge Neon 4 cyl Two Wheel Drive Manual
I have a 2004 Dodge Neon SXT, 2.0 SOHC, Manual transmition. I have recently been having issues where The car will sputter out when driving, and the check engine light comes on. By sputter I mean, when I go to take off in first gear, I get up to about 2500 RPM, then it sputters like there is no fuel going through the lines. Switch gears, and again about 2500 RPM give or take, and will continue this for each gear. Or when it chooses to work correctly. Lets say I'm doing highway speeds, it will cut out, as if no fuel. Let off on the gas, and wait till I'm down to say 30 mph. Then kicks back in.
I was assuming maybe something with the fuel pump, or fuel filter. But apparently there is no filter on this car.
Currently the check engine light is off. But I decided to hook it up to the computer and analize through this method.
I came up with 2 codes that say the same thing. Camshaft Position Sensor Interupped.
I've located the part on the car. But haven't gone any further.
Could you Please advise me as to if this is the problem?
Do you
have the same problem?
Sunday, August 22nd, 2010 AT 5:19 PM
JOEMERCHANT2006
Hi, I have the same exact car that had the same exact problem. It is the camshaft positioning sensor and it either had fluid leaking on it or it needs replacing. Mine needed replacing period. It is a pain in the neck and butt to get to but trust me it will fix the problem.
Also, if you find that the positioning sensor is fine, check the wiring, if any fluid touches the wiring, it's shot.
Sunday, September 19th, 2010 AT 11:59 PM
Recommended Guides
