2003 Dodge Neon CAmshaft positioning sensor
SHEDANCES
  • 2003 DODGE NEON
Engine Performance problem
2003 Dodge Neon 4 cyl Two Wheel Drive Automatic
I gotght the code P0016 and replaced the camshaft sensor and the crankshaft sensor then I went for a test drive and check engine light cam on again now when I read code I have a new one it is P0440 any Iddeas what next and what is new code? Thanks Teri
Do you
have the same problem?
Monday, September 6th, 2010 AT 2:50 PM
DOCFIXIT
  • EXPERT
440 is BIG evap system leak is gas cap on tight?
Monday, September 6th, 2010 AT 3:06 PM
SHEDANCES
Thanks I checked again and it went away just still getting the p0016 showing up as 2 codes. Thank Teri
Monday, September 6th, 2010 AT 3:53 PM
DOCFIXIT
  • EXPERT
Remove both cam and crank sensors inspect tone wheels any debris, bent rotate engine to see all of wheel
Tuesday, September 7th, 2010 AT 12:03 PM
SHEDANCES
Thanks Doc I will try that when I get home this eve. And thank you for not answering me with my question reworded as the other tech did. Teri
Tuesday, September 7th, 2010 AT 1:27 PM
Recommended Guides
