2001 Dodge Dakota engine wont start
MOPARMAN817
  • 2001 DODGE DAKOTA
  • 4 CYL
  • MANUAL
  • 165,000 MILES
Engine turns over will not start fuel pump is working
Wednesday, September 16th, 2009 AT 10:38 PM
JDL
  • 16,098 POSTS
Welcome to the forum. I need a little more info. With the engine cranking, do you have spark at the plugs? If no spark, check for primary voltage at the coil and injector, engine cranking. That voltage comes from the asd relay, I'm not saying the relay is faulty, maybe some reason the computer isn't grounding the relay?
Thursday, September 17th, 2009 AT 12:42 PM
