Replace fuel filter?
COLUMBUS
  • 2003 DODGE CARAVAN
  • 11,000 MILES
How to replace fuel filter on a 2003 grand caravan how do I do this?
Wednesday, March 14th, 2012 AT 2:54 AM
  • 52,797 POSTS
2 connectors at the fuel pump module need to be released. the filter is secured by 1 10mm bolt. the other end is up further by the tank. the tricky part is the tank has to be dropped about 5 inches to allow the 2 lines at the top of the tank to clear. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Monday, February 25th, 2019 AT 7:07 PM
JAY13
  • 6 CYL
  • 70,000 MILES
Locataion of fuel filter
Thursday, December 17th, 2020 AT 8:46 AM (Merged)
DODGEGUY43
  • 10 POSTS
Release fuel pressure, refer to the Fuel release procedure in this section.
Disconnect the negative battery cable.
Raise vehicle and support.
Support the fuel tank with a transmission jack.
Remove fuel line from the front of the tank.
Remove ground strap
Remove the inboard side of the fuel tank straps and front T strap fastner.
Lower the tank about 6 inches (FUEL FILTER).
Remove fuel lines from the fuel pump module.
Remove fuel filter from tank.
HENNECY
  • 6 CYL
  • 150 MILES
Where does the fuel filter go on a 2003 dodge caravan 3.3L
WRENCHTECH
  • 20,758 POSTS
The fuel filter is located on the fuel tank next to the fuel pump module. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/images/external/89095071.gif
STATIONARYMOM
2003 Dodge Caravan 6 cyl Front Wheel Drive Automatic
hi I would like to know the location of the fuel filter.
Thankyou
ZACKMAN
  • 4,202 POSTS
On top of the fuel tank, near the fuel pump module.
https://www.2carpros.com/forum/automotive_pictures/55316_03caravanfuelfilter_1.jpg
HIGGINS99
  • 2002 DODGE CARAVAN
  • 6 CYL
  • 120,000 MILES
. My van cuts out when Im driving but usually when the wind blows. I have talked to several people about it. I have told everything from fuel pump (because I jump from 10% ethonol from regular unleaded alot). I been told that its might be my fuel filter. I been told that its something to do with my cooling system
Thursday, December 17th, 2020 AT 8:47 AM (Merged)
  • 108,328 POSTS
Hi:
It could be a fuel pump or filter, but it sounds more like an electrical problem to me. Have you had the computer scanned for trouble codes? If not, stop by an Auto Zone or other nationally recognized auto parts store and have the computer scanned for trouble codes. Then we can go from there to try and fix the problem.
Let me know what you find. Also, keep in mind places like Auto Zone will scan it for free.
ABBAS
  • 2001 DODGE CARAVAN
  • 122,766 MILES
How to replace gas filter dodge 2001
Thursday, December 17th, 2020 AT 8:48 AM (Merged)
REMOVAL
Release fuel pressure, refer to the Fuel release procedure.
See: Fuel Pressure Release
Remove ground strap
Fig. 1 Fuel Filter
Lower the tank about 6 inches (Fig. 1).
JDL
  • 16,098 POSTS
I looked at caravan se 3.3 engine. The fuel filter is located close to the fuel pump module. Make sure there is no pressure on the fuel system. Take negative battery cable loose, Safely raise and support the vehicle. Use transmission jack to lower tank about 6 inches, so you can get at the filter. That means, electrical connectors--fuel lines loose, whatever it takes to drop the tank a few inches.
