Six cylinder two wheel drive automatic 93,000 miles.
Where is the crankshaft sensor located on this car? I cannot find it. Do I need to remove the intake? I see wires going under the intake but cannot tell what they are for.
Wednesday, August 27th, 2008 AT 5:18 AM
MECHANIC
The crankshaft sensor is located at the front of the engine down at the timing belt pulley. You will need to remove the timing belt cover. here is a diagram to help you see what I am talking about. The six.
Here is a guide that can give you more information on the job:
Here is what it will be like (below) for four and six cylinder engines.
Cheers
Images (Click to make bigger)
SPONSORED LINKS
Wednesday, August 27th, 2008 AT 5:29 AM
AG
MEMBER
I looked for about an hour last night in this area and could not find it. Is it under something else or hidden? I have the new sensor and know what it looks like, but cannot see it on the car. I went to the Hyundai dealership and asked a mechanic. The crankshaft sensor is above the starter on the side of the block. A bit hard to get to, but I changed it and car is running again.
Wednesday, August 27th, 2008 AT 7:20 AM
CARGURU225
MEMBER
1 POST
2004 HYUNDAI SANTA FE
2.4L
4 CYL
Where is the crankshaft position sensor?
Thursday, December 29th, 2016 AT 6:32 PM
(Merged)
HMAC300
MECHANIC
Here are some pictures that should help you:
(Merged)
COMALTAB86
MEMBER
1 POST
2003 HYUNDAI SANTA FE
6 CYL
4WD
AUTOMATIC
130,000 MILES
Where is the crankshaft positioning sensor located for a Hyundai Santa Fe 2003 2, 7 4x4?
SPONSORED LINKS
(Merged)
MECHANIC
See below:
Image (Click to make bigger)
(Merged)
MUSA BELLO
MEMBER
2008 HYUNDAI SANTA FE
2.7L
V6
4WD
AUTOMATIC
146,000 MILES
I want to locate the sensor, and possibly see the part number. Or if any one knows how to kindly help me?
(Merged)
WRENCHTECH
MECHANIC
The crankshaft sensor is in the side of the block, behind the exhaust manifold.
Part#
391803E100 $74.27
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
Hey MUSA,
The crankshaft position sensor is in the side of the block, behind the exhaust manifold.
Here is a diagram to help you locate it:
Please let us know what you find so it will help others.
Best, Ken
Thursday, December 29th, 2016 AT 6:33 PM
(Merged)
MANOLO GONZALEZ
MEMBER
Four cylinder front wheel drive manual.
Where is the crankshaft position sensor and how long does it take to replace on a 2.4L?
My 2004 Hyundai Santa Fe will not start. I already installed a new fuel pump and still same. I was thinking may be the crankshaft sensor but I do not know where it is. How can I find it?
SPONSORED LINKS
(Merged)
KHLOW2008
MECHANIC
You do not change parts and hope that it works. It is going to be costly and a waste of time and money unless you are extremely lucky.
You need to start with diagnostics to find out what is missing causing the non starting.
(Merged)
MCAVINEE
MEMBER
2.7L
V6
2WD
AUTOMATIC
175,000 MILES
My SUV suddenly would not shift into second gear going down the highway. I babied it home and noticed also that placing it in reverse the engine immediately quit. Idle the car and it is fine. Placing it in drive it jumps. So I took out my computer check tool and it said the crankshaft sensor was bad.
So I guess I need to know where this is located on the engine? Thanks, Mark
Thursday, October 12th, 2017 AT 3:11 PM
(Merged)
HMAC300
MECHANIC
I doubt it is your crank sensor, but here is location in picture. If it still does it have a transmission professional check it. It may be a governor or in need of transmission rebuild.
(Merged)
MCAVINEE
MEMBER
Reason I said the sensor is my tester gave me the p003 and said crankshaft position sensor. Somebody told me that I would have to remove the timing belt cover and crankshaft pulley. You are showing the sensor at the top of the engine?
