Crankshaft position sensor location?
ANONYMOUS
  • 2002 MITSUBISHI MIRAGE
  • 90,000 MILES
What are the step to replace the crankshaft sensor on the 1.5
Tuesday, March 12th, 2013 AT 4:40 PM
KHLOW2008
  • 41,814 POSTS
1. Disconnect negative battery cable. Remove under cover. Remove all accessory drive belts. Rotate crankshaft clockwise so that No. 1 cylinder is at TDC of compression stroke. Holding crankshaft stationary, remove crankshaft pulley.
2. Place jack under engine. Support engine so there is no weight on engine mount bracket (timing belt end of engine). On vehicles equipped with A/C, move A/C relay box and drier assembly (hoses attached) out of way to remove engine mount bracket. On all vehicles, remove engine mount bracket-to-engine bolt and nut. Remove engine mount bracket-to-body through-bolt. Remove engine mount bracket.
3. Remove water pump pulley. Remove power steering pump and bracket with hoses attached, and secure out of way. Remove oil dipstick tube. Remove timing belt upper and lower covers. See Fig. 5.
4. Rotate crankshaft clockwise to align timing mark on camshaft sprocket with mark on cylinder head.
5. Remove Crankshaft Position Sensor.
Tuesday, March 12th, 2013 AT 5:43 PM
PIGGY6532
  • 2001 MITSUBISHI MIRAGE
  • 4 CYL
My car has a code for a crankshaft position sensor. Can you send some diagrams that show where this part is located on my car. I have the part, but I can't find it- or how to replace it
Saturday, August 1st, 2020 AT 12:19 PM (Merged)
HMAC300
  • 48,601 POSTS
Pic is on ly location we have.
PIGGY6532
Thank you for the reply. Is there any way you coukd describe the location-
What happened was my father replaced water pump then this code happened and car won't start.
Now we are both having a hard time finding it. Do other parts need to come out in order to see the Crank shaft sensor? Is there other more identifable parts surrounding it?
Any help would be appreciated. I'm broke and wish is could have it repaired.
But professional advice is a good start
HMAC300
  • 48,601 POSTS
We have no pictures of where it is other than what I've sent look near harmonic balancer on side of engine in that area
ELCHAPZ81
  • 5 POSTS
  • 12,000 MILES
To what relay or from where does the crankshaft sensor feed from? And when it grounds to? Thank you
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
I can provide a wiring diagram for you but I have a question first. Is your engine size a 1.5 or 1.8 liter and also is this a manual or automatic transmission? Let us know this information and we will be happy to help. Thanks for using 2CarPros.
Danny-
ELCHAPZ81
  • 5 POSTS
It is a 1.8 with automatic transmission.
DANNY L
  • 5,648 POSTS
Hello again.
Here is the diagram for your car. I have attached the picture as well as a tutorial how to check wiring. The colored wires number 12 and 23 connect to the PCM (Power-train Control Module). Hope this helps and thanks again for using 2CarProS.
Danny-
