Chrysler no start Mini van
DAVE IN WPG
  • CHRYSLER VAN
I have a 1995 chrysler mini van caravan 140,000 on a rebuilt engine 3.0litre engine. Now my problem is this my wife went out van worked fine she came home and we were going out that evening and nothing except the starter whinning and this was it. So I took the starter in and they said it was fine so the person that checked it had doubts so I just bought a new one reman actually anyway after this was installed nothing still the whinninh like it wanted to go but after a few turns it just seemed that the only thing that was turning over was the starter. I have spark I have fuel because after I crank it a few times I smell fuel and I hear the buzzing at first when I crank it so the fuel pump is working. Now I was wondering if the starter relay would do this? And if so where is this relay? Or maybe something else I cant get codes out of it because I have removed the cables when I threw this new starter into it but the wife said it was running fine before and then like I said when we went to go out that night just the starter was whining and wouldnt start. Thanks for any help here. And if there is anybody that needs some help as well well i`ve got alot of insight on the minivan as i`ve been at these for 5 years now and do know these pretty good so ya I can also be of help. Take-care.
Sunday, May 28th, 2006 AT 2:24 PM
SDALTON19
  • 87 POSTS
Pull the starter back out and look at the flywheel see if any teeth are missing or damaged
Sunday, May 28th, 2006 AT 2:36 PM
DAVE IN WPG
  • 10 POSTS
Forsure i`ll try this thanks alot but if i`m right I think I did this already and all were ok but i`ll give this another shot
dave
Sunday, May 28th, 2006 AT 3:28 PM
DAVE IN WPG
  • 10 POSTS
My son just informed me dad this was the first thing you had looked at so ya I have done this!
You see now I just tried to start it up and it seems that just the starter is going nothing else just this? Wierd it dont even sound like the engine itself is turning but i`ve looked and the gears are all going around so it isnt the timing belt the rotor turns i`ve removed the cap and watched and its going so? Anyway this has me stumped for once usually I can get it going no matter but vehicles are a funny thingggggg
thanks
dave
Sunday, May 28th, 2006 AT 3:55 PM
DAVE IN WPG
  • 10 POSTS
Is there a way one can test the throttle position sensor in this van? And the coil? Thanks I know there is a way but I forget now
thanks alot
dave
Monday, May 29th, 2006 AT 12:02 PM
SDALTON19
  • 87 POSTS
Ok if the rotor is moving then the engine is turning over however if it sounds like just the starter it may mean you have no compression this could be becouse the timing belt jumped timing take a look at the timing belt under the cover see if tis frayed if so check the timing marks and make sure they line up if the engine sounds like what your describing a coil would have nothing to do with this nor would the throttle position sensor let me know what you find also I have seen a few engines where the camshaft broke in half this could also be the problem but check timing belt first
Monday, May 29th, 2006 AT 12:58 PM
DAVE IN WPG
  • 10 POSTS
I`m gonna check this out but I have seen the belt moving but true might have slipped off or jumped a notch or 20 (9smile))
thanks bud
DAVE
Monday, May 29th, 2006 AT 1:57 PM
DAVE IN WPG
  • 10 POSTS
Well i`ve looked at the timing belt and all is alright there with this, now still i`m just getting the starter running and it seems like there is no compression happening like it normally sounds when it kicks over I dont hear this? The cam shaft is ok its not broken. Now i`m really mixed up here everything seems alright but wont crank over i`ve even changed the oil and cleaned up the plugs because it was flodded I did smell gas on each of the 6 plugs so I did this and then when I went to try and start it again I smelled gas all over again? And so I took off the hose going to the throttle body and it had some oil and gas mixed? I`ve never seen this before wow! Something new at every corner it seems lately.
Thanks for any help anybody can give on this issue
DAVE :roll:
Monday, May 29th, 2006 AT 11:13 PM
DADDYJOJO35
  • 5 POSTS
I know you checked the oil for water but try pullink the dipstick wipe the oil with your fingers and smelling it is there gas in your oil? If so posibaly a blown head or maybe even motor
Sunday, June 4th, 2006 AT 12:20 PM
DAVE IN WPG
  • 10 POSTS
Well along story here but got it all fixed and to say the least it was the water pump was going and I knew this but ignored it and yes it finally siezed up on me causing the timing belt to slip causing this no start and ya the oil was JUST FULL OF THE GAS SO ALSO DID A CHANGE OF THIS AND I`M ALSO GOING TO DO ANOTHER IN A WEEK OR SO JUST TO BE ON THE SAFE SIDE
THANKS TO ALL WHO HAVE TRIED HELPING IN THIS AREA OF AUTO MECHANICS AND IF THERE IS EVER SOMETHING I CAN HELP OUT WITH ALSO FEEL FREE TO LET ME KNOW AND IF I CAN HEY!
NOT A PROBLEM BUT FOR SOME REASON THIS ONE REALLY JUST STUMPED ME MUST BE GETTING OLD((43)) SMILE BUT NEVER THE LESS I`M HERE FOR U FOLKS AS WELL
TAKE CARE AND HAPPY FIXING DAVE IN WINNIPEG
ALWAYS AROUND SOMEWHERE GUYS GIRLS!
Sunday, June 4th, 2006 AT 7:03 PM
DAVE IN WPG
  • 10 POSTS
Well i`ve got this problem here to do with half shafts on a 1995 dodge caravan 3.0l front wheel drive of course. Now my question here is this I cant remember if the half shaft on the drivers side being the smaller one as there are 2 one long and 1 short now the short one here should the shaft go in all the way to where the shaft is flush with the tranny housing or should it protrude some out of the transaxle? Because mine protrudes some and to me it looks like just 2 much
thanks alot
dave
Monday, June 5th, 2006 AT 8:04 PM
CARAVANOGRE67
  • 22 POSTS
The short one goes on the drivers long one on pass and yes they will stick out about 1.5 inches past flush on the bearing pack have fun becauce that is what I am doing right now changing axels and shafts
Thursday, August 3rd, 2006 AT 12:04 AM
