2002 Chrysler PT Cruiser Alternator or?
ROGERDUQ2
  • 2002 CHRYSLER PT CRUISER
  • 4 CYL
  • FWD
  • MANUAL
  • 65,000 MILES
Hi. We recently changed the battery, after my wife had to get it jump started by one of her girl friends who crosswired for a bit I am now finding out and caused some arcing and smoke and the whole bit. Sigh. Anyways I replaced the battery and after running for a little bit the battery indicator came on so tested the out put under load and the reading was 11.3 volts, indicating an apparent bad alternator. Purchased a new Mitsubishi Alternator and now I still get an 11.3 volt reading under load. And btw. These alternators are a pain for a home garage repair.
Friday, January 1st, 2010 AT 1:10 PM
Hi rogerduq2, Welcome to 2carpros and TY for the donation and selecting us as your auto repair site Feel free to ask questions at anytime and Merry Christmas and a Happy New Year 2010
On the fuse block lower left front of dash check fuse no.10 and 13 also at power distribution center on left side of engine compartment fuse no.13, also check the fusible link dark green between the starter and alternator-if all these fuses are okay-your problem could be coming from the computer field generation driver circuit within-
http://www.2carpros.com/forum/automotive_pictures/12900_c1_17.jpg
http://www.2carpros.com/forum/automotive_pictures/12900_c2_16.jpg
Friday, January 1st, 2010 AT 3:53 PM
ROGERDUQ2
  • 9 POSTS
Is this the pcm or a diff part that you are referring to. Lol
Friday, January 1st, 2010 AT 4:00 PM
Yes sir its the PCM also known as ECM, ECU, VCM, etc-called the computer
Friday, January 1st, 2010 AT 4:02 PM
ROGERDUQ2
  • 9 POSTS
. Looks like the green wire/fusible link is burned out. What ohms should I be looking for and what amperage would this be carrying it appears to be 18ga wire etc
Friday, January 1st, 2010 AT 5:05 PM
If you stab it with a test light before and after the link the test lite should lit both ways if its good-
Friday, January 1st, 2010 AT 5:28 PM
ROGERDUQ2
  • 9 POSTS
Yes we found the fuse link between the starter and alt is melted down. Where do you even find 10 gauge fuse link, Autozone et all does not seem to carry it, is there an in-line fuse that would hold on this and if so what amperage would it need?
Saturday, January 2nd, 2010 AT 11:32 AM
Fusible links are 4X smaller than the wire it protects-In your case I'll use no.18 AWG
Saturday, January 2nd, 2010 AT 11:36 AM
ROGERDUQ2
  • 9 POSTS
So I can just remove the old 10G Fuse link that is melted and replace with a piece of standard 18 WGA wire then if I interpret this correctlt
Saturday, January 2nd, 2010 AT 12:44 PM
Yes Sir-affirmative on that
Saturday, January 2nd, 2010 AT 3:02 PM
ROGERDUQ2
  • 9 POSTS
Thank you. Will give it a go.18 guage is quite a bit thinner than the 10 guage fuse link that was in there. Lol
Saturday, January 2nd, 2010 AT 4:47 PM
ROGERDUQ2
  • 9 POSTS
Is there a difference betwee 18 gauge wire and 18 WGA? Replaced it with 18 Gauge wire and it just burned out after a minute or two.
Saturday, January 2nd, 2010 AT 7:42 PM
Try no.16AWG (american wire gauge) don't work, go to no.14 or you can pull one out of a junk car-
Saturday, January 2nd, 2010 AT 8:50 PM
