idles rough
2006 CHRYSLER PT CRUISER
200,000 MILES
BIGWILL9121
Ok here it is. When my car idles it idles rough. ive had it hooked op to a computer but it only showed that my cooling fan was out, which i already knew. it has been over heated once or twice. but when i put new plugs in it it straightens out. it does have close to or over 200,000 miles. what is the most likely problem im having and what do i need to fix this?
Jun 19, 2013 at 2:16 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
Hello
This guide will help
Jun 19, 2013 at 5:59 AM
BIGWILL9121
I ment to add in the question that when i pulled the plugs, the plugs in cylenders 1 and 2 where covered in oil. this being said i dont think its the fuel pressure.
Jun 20, 2013 at 12:54 AM
HMAC300
  • 48,601 POSTS
if the plugs are covered in oil then you have a more serious problem thatn a fuel pressure regulator. check compression on allcylinders
Jun 20, 2013 at 5:28 AM
BIGWILL9121
U thinkin that my rings r out or goin out?
Jun 20, 2013 at 5:51 PM
HMAC300
  • 48,601 POSTS
cold be valve seals too but check compression
Jun 21, 2013 at 6:49 AM
BIGWILL9121
If i check the compression and its good then its the valve seals, and if not its the rings. is that what ur sayin?
Jul 6, 2013 at 11:32 PM
HMAC300
  • 48,601 POSTS
unless you change the plugs your roughness at idle or anywhere wont go away. check your compression dry on all 4 then wet by spraying oil in cylinders send me the readings.
Jul 7, 2013 at 5:34 AM
US7492
2006 Chrysler PT Cruiser 4 cyl Front Wheel Drive 76854 miles
my call will sometimes stall or idle rough does it with and without ac on but worse with it on sometimes all dash lights will flash and odemeters bounce when this happens any suggestions as to what might be the problem?
Jan 10, 2020 at 1:48 PM (Merged)
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
FATMAN
Had timing belt replaced as well as cam positioning sensor but I am still getting same error codes, any suggestions? Idles rough, acceleration suffers at 3500 rpm, mpg has also gone down
  • 110,190 POSTS
Check wiring .to the cam sensor for corrosion, check catalytic converter for plugging, make sure timing is correct
FATMAN
thanks there is a good possibility that the cat is bad now that u mention it. where can i find the cam sensor at?
PHILPMDA21
2004 pt cruiser starts idling rough when I turn on a/c
WRENCHTECH
  • 20,761 POSTS
Turning the A/C on simply adds more load to an engine that likely had a problem already. It could be many things like a vacuum leak, ignition problem, fuel problem or more serious internal problem.
JBUCKNER5
I'm stumped. I have replaced the plugs 3 times, the coil and wires twice, checked the wiring for proper continuity, and replaced the PCM with a reman. Every time I reset the DTC codes, the vehicle will run fine until about 2000 rpm then start missing and through P2305 first, followed by P0300 then P0352. Plugs 1 and 4 look clean and plugs 2 and 3 look dirty. I have cleaned the MAP and the IAT. Both coils show 0.45 ohms primary and 11k ohms secondary.
I have checked the Crank and cam position sensors and and associated all wiring. I cannot think of anything else the problem could be other than the new PCM. Any suggestions?
CARADIODOC
  • 34,309 POSTS
You gotta have fuel too. Try switching two injectors to see if the misfire goes to a different cylinder.
JBUCKNER5
I'll give it a try this weekend. That's the only thing I didn't look at.
Jan 10, 2020 at 1:49 PM (Merged)
JBUCKNER5
Took the car to the dealer. Found out the PCM had to be flashed a second time. They also did an update. There is a service bulletin on the new recommended spark plus. Champion Copper Plus. The PCM was manufactured by Auto Computer Exchange. After a call to their support about the issue, several hang ups and dead end transfers, and the asinine response from their support, I will never use them again and will recommend to everyone I know to find a different company. From my experience, they do a half-assed job on the PCM's and do not want to support their work.
LANCE SHOCKLEY
Our PT Cruiser is running rough after you drive it about 5 miles. This started after I changed the plugs, wires, and coil yesterday. I have since changed the intake gaskets and MAP sensor and still no luck. I am getting codes P0352, P0351, P0300, P0171.
WRENCHTECH
  • 20,761 POSTS
You are getting codes for coil primary circuits so something went wrong with the coil change. Check you work, especially the coil connectors.
LANCE SHOCKLEY
Changed from one coil brand to another. This one does the same thing.
WRENCHTECH
  • 20,761 POSTS
The computer says there is a problem with the primary coil circuit so you need to look at it again.
LANCE SHOCKLEY
Switched back to the factory coil. All is well now.
JOE ROCKS
2003 Pt. Crusier turbo automatic has a rough idle and sounds like a misfire when in park or when in gear at a stopped position. Seems to run fine when in park when you hit the gas or when you are driving. Use premium gas all the time. Seems to take 8 to 10 seconds after you start the car before it starts to run rough. Put new plugs and wires on, didnt help. Took it to the dealer, they did all there tests, couldnt find the problem. No check engine light comes on. Cant find any vaccum leaks either.
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1.Defective spark plug.
9.Oxygen sensors.
WRENCHTECH
  • 20,761 POSTS
That is good. You also had a lean code so make sure you did not leave any hoses disconnected.
JUSTFRANK2002
I figured my 2002 Cruiser was due for a tune up as it experienced hard starting and a rough idle until it warmed up. I said hey what the heck do the timing belt too. To date I have replaced the timing belt, alt. belt, air-conditioning belt, water pump, radiator, anti freeze, engine oil and filter, transmission oil, thermostat, spark plug wires, spark plugs, PCV Valve, EGR Valve, removed and cleaned the throttle body and removed cleaned and measured the IAC Valve then replaced all 4 fuel injectors. I still have a hard starting problem and a rough idle but now all the time.
If I had any money left I would not be here looking for a free answer.
  • 110,190 POSTS
Wow! You replaced just about everything. Has the check engine light come on? Have you checked the temp sensor?
SAMANTHA155
Engine Mechanical problem
2002 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic
My car has a shaky idle, almost like a misfire. the system is tossing a misfire code in cylinder 3 at the mechanics, I have paid to replace the plugs, wires, coils, and it has helped, however the dealer reccomened a compression test, and cylinder three was 125 and the other 3 were at 175, what does this mean? is the repair possible? are there anyother things that could be wrong with the car?
BMRFIXIT
  • 19,053 POSTS
That is a bit low than the others
try a wet compression
and cylinder leak test
did you lose a timing belt and if so
suspect valve
DANAUTHIER
  • 156 POSTS
How many miles are on your cruiser?
I agree with BMRFIXIT, Have them do the wet compression and cyliner leak down tests.
The chrysler 2.4lL is what is called an interferance engine, if the timing belt breaks the piston(s)can come in contact with the valve(s) and damage them.
I have also seen numerious head gasket and head warpage problems with the 2.4l engine. With a 50 pound difference between #3 and the other cylinders I would defiinately recommed futher diagnosis if your plan is to keep the vehicle.
Thank to BMRFIXIT for his good advice.
Hope this info helps, let us know what you find.
Thank you,
Dan
EMT123
i started having trouble with my car yesterday. i drove it into a heated garage to let it warm up and to check for leaks. when i went to start it up to go out of the garage it began to idle very roughly and tends to jerk. i am wondering what this is and how to fix it.
  • 110,190 POSTS
HAs the check engine light come on? Have you checked for vacuum leaks? Fuel pump pressure? When was the last tune up?
