1998 Chysler Grand Voyager my van wont get fuel
1998 CHRYSLER GRAND VOYAGER
270,000 MILES • 6 CYL • FWD • AUTOMATIC
LOMAR79
i was driving when my van just sudenly stalled as if i was out of gas.i have a quarter tank of gas but even when i try to restart it it wont start as if i dont have any gas can you help?
May 4, 2008 at 10:31 PM
  • CAR REPAIR CONTRIBUTOR
Do below to determine if its a fuel or ignition problem
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
May 4, 2008 at 10:34 PM
