I am trying to figure out where the engine coolant sensor is located?
NHILTON1
  • 2005 CHEVROLET TRAILBLAZER
  • 106,888 MILES
The engine is a V6, and the upper radiator hose is slightly to the passenger side, and hubby says the thermostat is there, I can't seem to find the sensor, a picture would be great if you have one, as I am going insane and want to fix it in the morning myself. Any help would be greatly appreciated. What all do I need to take apart, the videos on youtube does not help either they are not car specific.
I would make a donation if I could, I have already spent a fortune on this vehicle as you can well guess from all of the issues that the Trailblazers have.
Friday, October 7th, 2011 AT 12:02 AM
SATURNTECH9
  • 30,869 POSTS
Left front of engine block near alternator its screwed into the head no specials tools just a deep socket. Here are the diagrams below to show you where the coolant temperature sensor is on both 6 and 8 cylinder engines. Check out the diagrams (Below). Please let us know what you find.
Saturday, October 21st, 2017 AT 1:01 PM
NHILTON1
But you need more tools I assume you have to remove the alternator
SATURNTECH9
  • 30,869 POSTS
Do you have the 4.2L or the 5.3L engine?Because I just caught you out 6 as the engine I thought you put 8 so thats the location I gave the sensor for. The trailblazer has a inline 6 or V8 engine. If you have a 6 cylinder is a inline 6.
EDUALAV
  • 2003 CHEVROLET TRAILBLAZER
  • 6 CYL
  • 4WD
  • 110,556 MILES
Hoe yo install coolant temperature sensor
Monday, November 2nd, 2020 AT 3:25 PM (Merged)
ENGINE COOLANT TEMPERATURE (ECT) SENSOR REPLACEMENT
REMOVAL PROCEDURE
NOTE: Use care when handling the coolant sensor. Damage to the coolant sensor will affect the operation of the fuel control system.
1. Turn the engine OFF.
2. Disconnect the negative battery terminal. CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
3. Drain coolant below the level of the ECT sensor. Refer to Draining and Filling Cooling System (Body Vin Code 6)Draining and Filling Cooling System (Body Vin Code 3) in Cooling System.
4. Disconnect the ECT sensor electrical connector (1).
5. Remove the drive belt and the generator.
6. Carefully remove the ECT sensor (1).
INSTALLATION PROCEDURE
NOTE:
*Use care when handling the coolant sensor. Damage to the coolant sensor will affect the operation of the fuel control system.
*Replacement components must be the correct part number for the application. Components requiring the use of the thread locking compound, lubricants, corrosion inhibitors, or sealants are identified in the service procedure. Some replacement components may come with these coatings already applied. Do not use these coatings on components unless specified. These coatings can affect the final torque, which may affect the operation of the component. Use the correct torque specification when installing components in order to avoid damage.
1. If installing the original sensor or a new sensor without sealant, apply thread sealer P/N 12346004 or equivalent.
2. Install the ECT sensor. NOTE: Refer to Fastener Notice in Service Precautions. Tighten Tighten the ECT sensor to 16 N.M (12 lb ft).
3. Connect the ECT electrical connector (1).
4. Install the generator and the drive belt.
5. Connect the negative battery terminal.
6. Refill the engine coolant. Refer to Draining and Filling Cooling System (Body Vin Code 6)Draining and Filling Cooling System (Body Vin Code 3) in Cooling System.
BIKERTHUG
  • 6 CYL
  • 64,000 MILES
Where is the coolant temp sensor located
IMPALASS
  • 3,112 POSTS
Hello - bikerthug
Here is the info you requested
Hope this helps.
If you would like to offer feedback on your experience with me/us - feel free to go into the blue "Give Feedback" area under ImpalaSS
https://www.2carpros.com/forum/automotive_pictures/248015_102980753_1.jpg
REMOVAL PROCEDURE
https://www.2carpros.com/forum/automotive_pictures/248015_1_29.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_2_21.jpg
NOTE:
https://www.2carpros.com/forum/automotive_pictures/248015_3_18.jpg
Install the ECT sensor. NOTE: Refer to Fastener Notice in Service Precautions. Tighten Tighten the ECT sensor to 16 N.m (12 lb ft) .
https://www.2carpros.com/forum/automotive_pictures/248015_4_9.jpg
BIKERTHUG
  • 6 CYL
  • 64,000 MILES
Where is this coolant temp sensor located
BLACKOP555
  • 10,371 POSTS
Front right engine block near the generator. See picture bellow.
BLACKOP555
  • 10,371 POSTS
https://www.2carpros.com/forum/automotive_pictures/66751_ects_1.jpg
JASONN
  • 6 CYL
  • 4WD
  • 87,000 MILES
Where and how to change a coolent temp. Sensor on my 03 trailblazer.
https://www.2carpros.com/forum/automotive_pictures/12900_ect_14.jpg
REMOVAL PROCEDURE
1.Turn the engine OFF.
2.Disconnect the negative battery terminal. CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
3.Drain coolant below the level of the ECT sensor. Refer to Draining and Filling Cooling System (Body Vin Code 6)Draining and Filling Cooling System (Body Vin Code 3) in Cooling System.
4.Disconnect the ECT sensor electrical connector (1).
5.Remove the drive belt and the generator.
6.Carefully remove the ECT sensor (1).
NOTE:
1.If installing the original sensor or a new sensor without sealant, apply thread sealer P/N 12346004 or equivalent.
2.Install the ECT sensor. NOTE: Refer to Fastener Notice in Service Precautions. Tighten Tighten the ECT sensor to 16 N.m (12 lb ft) .
3.Connect the ECT electrical connector (1).
4.Install the generator and the drive belt.
5.Connect the negative battery terminal.
6.Refill the engine coolant. Refer to Draining and Filling Cooling System (Body Vin Code 6)Draining and Filling Cooling System (Body Vin Code 3) in Cooling System.
KEMA30
  • 6 CYL
  • 4WD
  • 106,800 MILES
My engine check light is on, and I took it to get a diagnostic test and they said the coolant sensor is defective. Where on my vehichle is this sensor located?
DENNYP
  • 1,823 POSTS
https://www.2carpros.com/forum/automotive_pictures/102900_coolant_1.jpg
(1) Engine Coolant Temperature (ECT) Sensor
(2) Engine Harness
(3) PCM C1
(4) PCM C2
(5) Powertrain Control Module (PCM) C3
DENNYP
  • 1,823 POSTS
Number 1 shows the connector for the sensor. You will find the sensor mounts to the engine just behind the alternator.
JCATRON
  • 8 POSTS
  • 2002 CHEVROLET TRAILBLAZER
  • 4.2L
  • 6 CYL
  • 4WD
  • 200,000 MILES
I replaced the engine which is an 2008-2009, but the head is for an 2002 4.2L. There are no ports for the water temperature sensor to go due to the change in design from Cheverolet. Is there another port I can use in the block for this sensor?
Monday, November 2nd, 2020 AT 3:26 PM (Merged)
  • 52,797 POSTS
Good morning.
I attached a picture of the location of the coolant sensor for the 2002 for you to view. It needs to go there and cannot be relocated.
JCATRON
  • 8 POSTS
I know where the stock sensor location is. I do not think you understand the question. There is no threaded water temperature sensor ports on both my block or my head.
JCATRON
  • 8 POSTS
So Roy, do I drill and tap the 2008 block to put in that location? Or is there another passage on the block that can be used? There is a plug beside the thermostat to the right
  • 52,797 POSTS
I posted the picture for the 2002. Is that what you installed?
If it is next to the thermostat, yes as that is the location of the sensor. Make sure you use a pipe thread tap.
