Replaced blower motor and control module. Also replaced the 10 amp fuse under the hood.
Sunday, July 21st, 2019 AT 11:15 AM
KEN L
MASTER CERTIFIED MECHANIC
Does the fuse have power this guide will help and there are two other fuses that must be checked as well. Here are the blower motor wiring diagrams so you can see how the system works and which fuses to check also with a guide to help you check for power along with the fuse locations below.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Images (Click to make bigger)
SPONSORED LINKS
Monday, July 22nd, 2019 AT 3:28 PM
HOT IN PA
MEMBER
Fixed. It was the 40 amp fuse. Must have blown when the AC went out. Thank you.
Monday, July 22nd, 2019 AT 3:31 PM
KEN L
Nice work, we are here to help, please use 2CarPros anytime.
Tuesday, July 23rd, 2019 AT 12:46 PM
DANA1550
MEMBER
1 POST
2003 CHEVROLET TAHOE
V8
4WD
AUTOMATIC
115,000 MILES
It appears no fuse is blown. Is this the fan motor itself?
Tuesday, July 23rd, 2019 AT 1:16 PM
(Merged)
2CARPRO JACK
MECHANIC
Grab a test light and check for power and ground at the motor. If it has both when turned on the motor is bad, otherwise it may be the blower motor resistor. Follow the wiresfrom the motor to the resistor, should be near the motor mounted in the HVAC plenum
SPONSORED LINKS
(Merged)
LANIJEFF
MEMBER
1 POST
V8
2WD
AUTOMATIC
99,000 MILES
The switch that contols the A/C & heater blower has settings 0 - 5. Initially, the blower quit working on setting 1, then it quit working on setting 2. Presently, you have to crank the blower up to setting 3 to get any air blow from the vents. The air blows out pretty hard on setting 3 so it becomes too much air very quickly. This same problem has happended before and I paid the dealer to fix it. I have seen the same problem in other cars. Obvioulsy, this is a common problem. Please advise how to fix it. Thank you very much for your help.
(Merged)
MECHANIC
Chances are the blower motor resister is bad. Stop at a nationally recognized parts store and get one. They are cheap. As far as replacement, it is located near the blower motor and has one electrical plug and (I think) two screws that hold it in place.
(Merged)
RGALIS
MEMBER
1 POST
2001 CHEVROLET TAHOE
155,500 MILES
My 2001 tahoe Rear blower not working nothing coming out rear either hot or cold front seems to be working fine checked blower fuses already did heater core flush checked under dash for blend door I am stumped.
Please help winter in coming
(Merged)
HMAC300
MECHANIC
This sounds like the blower motor has failed but to be sure we can check for power and ground back at the blower motor here is a guide and some diagrams below so you can get the problem fixed.
Cheers
(Merged)
ADRIENNE
MEMBER
My fan blower is not working. I replaced the resistor that was not it. What else could it be?
Image (Click to make bigger)
(Merged)
MECHANIC
Could be the blower motor itself and the blower switch-check and test
(Merged)
ADRIENNE
MEMBER
Thank you. I will try that next.
SPONSORED LINKS
(Merged)
ADRIENNE
MEMBER
How do you extract the fan motor?
(Merged)
TIDOJAXON4
MEMBER
1 POST
1999 CHEVROLET TAHOE
V8
4WD
AUTOMATIC
159,000 MILES
I installed a car stereo in my Tahoe myself. The heat was working fine before I started but then after I turned the knob for the heater and no heat blew through the panels, not even when I had it all the way on high. I checked to see if maybe some wiring either came undone or was not pushed all the way in and it was fine. I checked the fuses that looked like they might have to do with the heater and those were fine. The only thing I can think of is I may have pulled something loose near the engine because I disconnected the coolant container to try to find a place to run my power cable through. The other day I lifted the hood while my car was running and I saw hot air coming out close to the firewall closer to the passenger side of the car.
Tuesday, July 23rd, 2019 AT 1:17 PM
(Merged)
JDL
MECHANIC
Can you hear the blower motor running?
Where is that hot air coming from, that you were talking about?
(Merged)
TERRY LEE
MEMBER
V8
4WD
AUTOMATIC
189 MILES
Blower doesnt work on floor or heater works thru dash
(Merged)
MECHANIC
You are dealing with a vacuum leak. The air flow vents are actuated by vacuum. If there is a leak, it won't change direction. Check for leaks under the dash. If you are lucky, you may hear a hissing sound when the engine is running.
Let me know what you find.
(Merged)
TERRY LEE
MEMBER
My blower runs back wards high air is on low and off is on high if it shut off. No air thru defroster just dash
(Merged)
TERRY LEE
MEMBER
My heater motor wont shut off and runs back wards blows good out of dash but not defroster or floor
(Merged)
MECHANIC
You are dealing with a vacuum leak which is causing the air flow problem. Check under the dash for leaks. If you are lucky, with the engine running, you may hear a hissing sound from the leak.
As far as the electrical issue, wither the fan switch has shorted or the blower motor resister.
