2000 Chevy Silverado No heat through heater
CARTER96
  • 2000 CHEVROLET SILVERADO
  • V8
  • 171,500 MILES
Recently my trucks heater stopped working. It just blows cool air. It came back on for one day and has been out since. Would this be a thermostat problem or a heater core problem? If heater core how hard is it to change?
Saturday, January 19th, 2008 AT 7:37 PM
Good place to start is to check the coolant level and make sure its using the correct type of coolant and properly mixed for protection. Won't hurt inspect for a clogged heater hose/core-feel the hoses should be the same temperature if not something is wrong.
Could be also air mix or blend door not opening due to a malfunctioning actuator or vacuum or hose problem
Saturday, January 19th, 2008 AT 8:26 PM
