2005 Chevy Malibu antifreeze drain plug
CLAUDE5
  • 2005 CHEVROLET MALIBU
  • 4 CYL
  • FWD
  • 75,000 MILES
Looking for radiator drain plug, found what looks like it on drivers side, white nylon, has a open where you can insert 1/4 drive extension. Just turns, does nothing either way you turn it, will not tighten up or loose.
Do you
have the same problem?
Thursday, December 13th, 2007 AT 11:22 AM
SERVICE WRITER
  • EXPERT
You found it!
It can only be turned a half turn or it will break, it then can be pulled out enough to let the fluid drain, it doesn't came all the way out.
Thursday, December 13th, 2007 AT 11:30 AM
CLAUDE5
If it only turns, either way, does that mean it broke? If so, how do you replace it?
Thursday, December 13th, 2007 AT 12:50 PM
Recommended Guides
