Fast idle or very high RPM
  • 108,192 POSTS
First, have the computer scanned to identify a trouble code. It will tell you where a problem is coming from. Also, most parts stores will do it for free.
Next, check for vacuum leaks and make sure the idle air control solenoid is working properly. Either one could cause an idle problem.
Monday, January 9th, 2017 AT 4:01 PM (Merged)
ALPENA_BOI_21
  • 1995 CHEVROLET LUMINA
  • 4 CYL
  • FWD
  • 153,608 MILES
Engine Performance problem
1995 Chevy Lumina 4 cyl Front Wheel Drive Automatic 153608 miles
i own a 1995 chevey lumina and my engine revs for awhile then I shut the car off then it is normal again I have took the car to many different place and they dont know what is wrong with it hopefully you guys can tell me what is wrong with it ormaybe tell me how to fix this problem?
  • 108,192 POSTS
Hi:
Chances are there is a problem with the throttle position sensor (TPS) or the idle air control valve (IAC). However, I can't be sure unless you have the computer scanned for trouble codes. Take the car to a nationally recognized parts store and they should scan it for free. Let me know what codes they find.
JOE1953
  • 619 POSTS
  • 1997 CHEVROLET LUMINA
  • 3.1L
  • FWD
  • 196,000 MILES
When I start the engine up it will run but the engine want idle down after it warm up what is the cause why it idle high?
Monday, January 9th, 2017 AT 4:02 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
The idle speed is controlled by metering air into the intake so if the engine is getting any unmetered air from a leak anywhere, that will do it. It can also be a faulty IAC (idle air control).
JOE1953
  • 619 POSTS
Where is the IAC (idle air control) located can you send me a picture?
WRENCHTECH
  • 20,757 POSTS
It's on the side of the throttle body.
https://www.2carpros.com/images/external/58840085-1.gif
LATASHA601
  • 3.1L
  • V6
  • FWD
  • 129,422 MILES
I am havening problem with my vehicle idle up high while sitting still, When I crank the vehicle up while sitting still it doesn't idle up high but when I let it sit there while sitting still I say like about 5 minutes that's when it idle up high.
HMAC300
  • 48,601 POSTS
Check for a vacuum leak and clean throttle plate on both sides and iac hole with choke cleaner
KATIEMOM
  • 2001 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 140,000 MILES
2001 Chevy Lumina 6 cyl Front Wheel Drive Automatic 140000 miles
Hi, We are having high idle on our Lumina. It rarely happened in the winter but now is happening almost every time the car is started since the weather is warmer. It will rev up to 2000 rpms and will stay there until the car is shut off and restarted a few times. It has also stalled a couple times. Is there anything we can try to fix ourselves before we take it in for service? Could you please explain in detail? Thank you for any help it is very very appreciated!
SPEECECREW
  • 1996 CHEVROLET LUMINA
  • 6 CYL
  • 165,000 MILES
1996 Chevy Lumina 6 cyl Two Wheel Drive Automatic 165000 miles
The engine revs up and down when it is warmed up. It runs fine when cold. As it revs up and down I can give it a little gas and it smooths out for a few seconds then acts up again. I have check the vacuum lines and have replaced the mass air sensor with other old one. Could it be that I have another bad sensor or what. Thank You
  • 108,192 POSTS
HAs the check engine light come on? To me it sounds like a throttle position sensor (TPS). Let me know about the check engine light.
SONNYSGAL69
  • 9 POSTS
Car has a high idle when you put it in park and when it been running a while
SONNYSGAL69
  • 9 POSTS
Sometimes the check engine light comes on then sometimes itgoes offand is just fine.
SATURNTECH9
  • 30,870 POSTS
So you only have the P0507?Ou could have a vaccuum leak or dirty/bad idle air control valve.
LADYK61
  • 1998 CHEVROLET LUMINA
1998 Chevy Lumina 6 cyl
For the past year my chevy lumina occasionaly kicks into the high idle mode and will not stop. The car will race anywhere from 5 minutes to twenty minutes while driving. It does not matter if the car is in motion or at a stop light.I have sprayed gumout and power washed the carberator. The throttle moves freely.
JALOPYPAPA
  • 467 POSTS
Did you also remove and clean the idle air control valve on top of the throttle body? If it persists, you might replace the IAC.
DNGINEER87
  • 5 POSTS
I had a similar problem with a 1996 Lumina. It turned out to be the coolant temperature sensor. There was corrosion on the connector terminals. I cleaned them, put silicone grease on them to seal out water and the problem was solved. Apparently the corrosion changed the resistance of the sensor making the ECM think the engine was cold and needed high idle to warm-up the engine.
JAMEY KOESTER
  • 6 CYL
  • FWD
  • 154,236 MILES
Car chugs or fish bites when you push the peddel and has high idle when you start it
ITS A 1996 CHEVY LUMINA
Clean out the idle air control valve and test the MAP/TPS sensors
Monday, January 9th, 2017 AT 4:03 PM (Merged)
