HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Impala
Engine
Symptoms
Oil Leak
2001 Chevy Impala engine
DOMINGO12
MEMBER
2001 CHEVROLET IMPALA
4 CYL
2WD
AUTOMATIC
120,450 MILES
Anti-freeze leaking from top of engine
Thursday, January 24th, 2008 AT 10:18 AM
DENNYP
MECHANIC
Check your intake manifold gaskets for a coolant leak. You will usually see the leak at the corners.
Thursday, January 24th, 2008 AT 9:19 PM
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
Impala Oil Leak
Make: Chevrolet Model: Impala Engine: 3.8 V6 Year: 2000 Mileage: 169000 I Know A Lot Mileage But The Car Has Been A Great Car Since I...
Asked by
lordb90
CHEVROLET IMPALA
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
2006 Chevy Impala Oil Leak
Black Looking Boot In Center Of Belt Pulleys Seem To Be Leaking Oil. Any Input On The Name Of This Part Or What Could Be Causing The Leak
Asked by
aightball
1 ANSWER
2006
CHEVROLET IMPALA
2002 Chevy Impala Oil Leak
My Dad Came Home Yesterday And His Car Was Smoking From Under The Hood And It Smelled Like Burnt Oil. When He Opened The Hood He Noticed...
Asked by
dwayne47
2002
CHEVROLET IMPALA
I Have Had This Car For Several Years And Have Never Had A Problem With It. Today, I Took It To Have The Oil Changed And The Mechanic Told...
Asked by
goodfella1361
2002
CHEVROLET IMPALA
2004 Chevy Impala Engine Cooling Is Leaking
Engine Cooling Problem 2004 Chevy Impala 6 Cyl Front Wheel Drive Automatic My Engine Cooling Leaking And My Car Run Hot With Can I Do...
Asked by
malden
2004
CHEVROLET IMPALA
VIEW MORE
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Can You Fix a Head Gasket with a Sealer?
