2004 Chevy Colorado air condtion ground wire short (blower
LG4JACKSDOWN
  • 2004 CHEVROLET COLORADO
Air Conditioning problem
2004 Chevy Colorado Four Wheel Drive Automatic 82,000 miles
the blower does not come on but now and then has been checked and is good (was told ther is only 1 wire from blower) has new wire harnes new blower restor air compressor good but still will not work blower only comes on ones in awhile will be driving and it kicks on for awhile then kicks off cool air comes from vents just no blower thie is 2004 colorado 4 door 5 foot bed 5cylnder eng (would like a scamatic of air wireing and ground wires if possabile yhank you
Do you
have the same problem?
Tuesday, August 3rd, 2010 AT 10:41 AM
KHLOW2008
  • EXPERT
Hi lg4jacksdown,
Thank you for the donation.
Problem seems to be due to an intermittent power failure. I have sent the schematic and diagniostic files to you. However it must be noted that since problem is intermittent, the test might not be accurate and some wiggling test is required, ie wiggle wire connectors to confirm the terminals are secure.
Tuesday, August 3rd, 2010 AT 11:28 AM
Recommended Guides
