1996 Chevy Cheyenne codes
JTHOLT
  • 1996 CHEVROLET CHEYENNE
Engine Mechanical problem
1996 Chevy Cheyenne V8 Two Wheel Drive Manual
my truck has miss. I put it on a computer. It say there is a discorlation between the camshaft and the crankshaft sensors what does this mean? Code(p1345)
Do you
have the same problem?
Sunday, February 8th, 2009 AT 10:24 PM
BLUELIGHTNIN6
  • EXPERT
In other words the cam is not where it is supposed to be in reference to the crank. It could be the Cam position sensor, the crank shaft position sensor, the gear on the distributor or the timing chain. The quickest and cheapest check is the distributor gear which is also the most common to fail between these components.
Thanks for using 2CarPros. Com!
Monday, February 9th, 2009 AT 2:03 AM
Recommended Guides
